Mahindra emax 25 vs Kubota BX2670
   / Mahindra emax 25 vs Kubota BX2670 #11
I suggest you go to BUILD MY KUBOTA on Kubota's web site, and option a tractor for SSQA, that has SSQA available now. The SSQA option price will not be very different when it is available for the BX in 2017.
Here is Kubota's site:
http://www.kubota.com/configurator/productselector.aspx?pgId=1
As you have a FORKLIFT ~~~~ What are you going to use tractor forks for? Perhaps another attachment will be more efficient for your task(s).
Can't use the forklift outside. I don't imagine the ssqa is going to be that much more that the current system
   / Mahindra emax 25 vs Kubota BX2670 #13
Check out everything attachments website. I have the emax25 and I'm considering the same ssqa upgrade. I priced the ssqa, bucket weld on bracket and pallet forks at $1600. The one question I would ask is what you intend to lift? You're surely not attempting to move a pallet of bricks with a subcompact I hope.
   / Mahindra emax 25 vs Kubota BX2670 #14
mahindra is generally a better machine esp in that size range.i did all the specs and checks when i was buying my tractor.
   / Mahindra emax 25 vs Kubota BX2670 #15
   / Mahindra emax 25 vs Kubota BX2670 #16
Based off of what exactly?
Picking up material and loading into my truck. Moving small rocks and landscaping. Again I can't use the forklift outside.
   / Mahindra emax 25 vs Kubota BX2670 #18
trying it - reading about all of the specs and reading about the actual construction of the units. what else do you want. Geeez! been on a tractor of various brands for 45 years now.... that should count for something too i would say.
   / Mahindra emax 25 vs Kubota BX2670 #19
oh - as i have said before - the bx series is more of a glorified lawn tractor.
i had wanted one for maybe 6 years but when time came - i realized - STAY AWAY from it!
Fair enough. Have you cut lawn with yours?
1999 International F-4900 T/A Cab and Chassis Truck (A56858)
1999 International...
2014 Ford Escape SE SUV (A56859)
2014 Ford Escape...
Toro TRX-20 Walk Behind Trencher (A57453)
Toro TRX-20 Walk...
2025 GPS Equipment Trailer (A56859)
2025 GPS Equipment...
SDLL30 skid steer with bucket (A56857)
SDLL30 skid steer...
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55853)
Year: 2016 Make...
