Mahindra emax 25 vs Kubota BX2670
   / Mahindra emax 25 vs Kubota BX2670 #11
I suggest you go to BUILD MY KUBOTA on Kubota's web site, and option a tractor for SSQA, that has SSQA available now. The SSQA option price will not be very different when it is available for the BX in 2017.
Here is Kubota's site:
http://www.kubota.com/configurator/productselector.aspx?pgId=1
As you have a FORKLIFT ~~~~ What are you going to use tractor forks for? Perhaps another attachment will be more efficient for your task(s).
Can't use the forklift outside. I don't imagine the ssqa is going to be that much more that the current system
   / Mahindra emax 25 vs Kubota BX2670 #13
Check out everything attachments website. I have the emax25 and I'm considering the same ssqa upgrade. I priced the ssqa, bucket weld on bracket and pallet forks at $1600. The one question I would ask is what you intend to lift? You're surely not attempting to move a pallet of bricks with a subcompact I hope.
   / Mahindra emax 25 vs Kubota BX2670 #14
mahindra is generally a better machine esp in that size range.i did all the specs and checks when i was buying my tractor.
   / Mahindra emax 25 vs Kubota BX2670 #15
   / Mahindra emax 25 vs Kubota BX2670 #16
Based off of what exactly?
Picking up material and loading into my truck. Moving small rocks and landscaping. Again I can't use the forklift outside.
   / Mahindra emax 25 vs Kubota BX2670 #18
trying it - reading about all of the specs and reading about the actual construction of the units. what else do you want. Geeez! been on a tractor of various brands for 45 years now.... that should count for something too i would say.
   / Mahindra emax 25 vs Kubota BX2670 #19
oh - as i have said before - the bx series is more of a glorified lawn tractor.
i had wanted one for maybe 6 years but when time came - i realized - STAY AWAY from it!
Fair enough. Have you cut lawn with yours?
New/Unused Quick Attach Auger with Three Bits (A57453)
New/Unused Quick...
(8) 2" x 27' , 5 Ton Ratchet Tie Downs (New/Unused) (A59225)
(8) 2" x 27' , 5...
CASE IH MX220 MAGNUM TRACTOR (A58375)
CASE IH MX220...
John Deere 3025E (A53317)
John Deere 3025E...
2025 ZJG ZJ-13 Mini Excavator (A56857)
2025 ZJG ZJ-13...
2 Electric Pressure Washers (A57454)
2 Electric...
