Septic Pet Peeve
   / Septic Pet Peeve
Can you site an example where a single family home leach field has contaminated ground water? Or is it here say and unsubstantiated anecdote?
We have "failed systems" in our area (I served on the board of selectmen) But no health Disasters were reported. 'Fortunate perhaps....
Yes, there is plenty of evidence of failed systems causing health problems. For example, in Michigan, thousands of failed septic systems are entering into Michigan's drinking water. Thousands of failed septic tanks across the state threaten Michigan's waters | MLive.com
In Ohio, over 195,000 failed septic systems have been reported (1 in 3 homes). 31% of septic systems are tanking | The Columbus Dispatch
There is A LOT of info on Google showing how failed septic systems are causing problems throughout the USA.
According to the EPA
Failure rates for on-lot sewage septic systems across the country are reported at 10 percent annually. Inadequately treated sewage from failing septic systems is the most frequently reported cause of groundwater contamination
The most serious documented problems involve contamination of surface waters and ground water with disease-causing pathogens and nitrates. Other problems include excessive nitrogen discharges to sensitive coastal waters and phosphorus pollution of inland surface waters, which increases algal growth and lowers dissolved oxygen levels. Contamination of important shellfish beds and swimming beaches by pathogens is a concern in some coastal regions.
   / Septic Pet Peeve #22
I am hearing that our systems here in Washington musst be inspected every few yeas (?5?). Inspector shows up, takes quick look and hands over a bill. My tank is buried with no inspection port. Big tank and new field installed in 1976, pumped every 5 years. . They want to inspect, there's the shovel.
So they basically just do a sniff test?
   / Septic Pet Peeve #23
Sounds more like ignorance...
Even an over engineered system can be stressed... simply a stuck toilet flapper can saturate a leach field.
Worse is what gets flushed...
With proper care a septic can last for many decades and most are totally ignorant as to what is required.
Friends sold a home with a septic and never had a problem... reports all came back fine.
A family from the city bought it and soon had big problems... they installed a garbage disposal, had no lint trap on the washer and used a lot of bleach and anti-bacteria products... even in the dishwasher.
Everyone with common sense should know to keep bleach and antibacterial soaps out. I'd like to know what else everyone knows about that can take a toll on a septic system. Here are a few that I worry about and try to get the wife to pay attention to. I am not sure they all are true.
Too much water saturates the field. Excess laundry, showers, flushing, leaking toilet. Space showers and laundry out
No Previously mentioned bleach and antibacterial soaps
Keep Coffee grounds out
Use septic friendly soaps
No automatic toilet bowl cleaners
no Grease
No Grease dissolvers
Prevent tree and shrub roots near the leach lines
Pump the tank often to prevent solids from entering the leach lines
No garbage from garbage disposal
Don't drive on the leach field compacting the soil and potentially crushing the lines.
No cat litter
Others?
   / Septic Pet Peeve #24
From the reports I have heard, the don't even do that. Seem to be out for just the inspection fee...which isn't cheap. I forget the exact amount but it was in hte $300 range.
   / Septic Pet Peeve #25
When we had our system replaced about 4 years ago the cost was around $5K. It was a total gravity fed system. No mound or anything mechanical needed thankfully.
New neighbors at the new place are building. They have been told a mound system will be needed. $15K easy. Oddly on our property we have a gravity fed system here too that was just put in a about 3-4 years ago.
   / Septic Pet Peeve #26
no Grease
No cat litter
Others?
Thank's for the info, any thought on salt in the septic system from a water softener?
My son moved in to his 1st house and the water softener discharge goes into his septic system.
   / Septic Pet Peeve #27
That is because you are paying for his 'professional training', years of study and that eng on his signature.
Here we have that fee for the soil eng as well, and that is B4 they start to make the system.
That is $500. for him to determine where it should be as well as a perk test.
Now just hope the city inspector agrees otherwise you do another $500 test 100 ft away.
Heck they now have specs for the sand used in the fields and that is generally sand that has to be trucked from many miles away.
Now don't forget the separations from wells etc that require U survey your neighbors properties and their wells and fields.
Sure is getting rather pricey to build now days.
   / Septic Pet Peeve #28
What a crappy thread.
I've read this is a bad practice in general.
   / Septic Pet Peeve #29
In a perfect world...
excerpt taken from one of the links posted above.
“A properly maintained on-site treatment system is more sustainable than the centralized treatment systems,” said Stephens, whose consulting firm oversees construction of on-site systems.
He said municipal sewer systems dump more untreated sewage into lakes and rivers than all the septic systems in Michigan combined. State data support his claim."
   / Septic Pet Peeve #30
no Grease
No cat litter
Others?
Lint Trap of Filter on Washing Machine drain water...
Minimize rinse cycles or if allowed divert Washer to Grey Water System
Only human waste, water and septic friendly paper down toilet.
One of my friends has city water and a private septic... water has given problems in the past as it is heavily chlorinated at times.
Friends have been 35 years on a septic in a problematic area... all around families have had to go to mound systems... my friends are super cautious... they keep a used toilet paper waste paper basket and nightly it is burned... never any paper or chemicals go into the system.
Part of the cost of new install can be a mandatory service contract as part of monitoring....
Of course avoid anything sold as flushable... especially baby wipes!!!
2007 PETERBILT 379 TANDEM AXLE SLEEPER TRUCK (A53426)
2007 PETERBILT 379...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2021 Chevrolet Equinox LS SUV (A53424)
2021 Chevrolet...
2016 Chevrolet Sonic LS Hatchback (A53424)
2016 Chevrolet...
2010 HEIL TOKEN TRAILER (A53843)
2010 HEIL TOKEN...
Case 950 8 Row Air Planter (A55301)
Case 950 8 Row Air...
