Moving Old Truck 20' Cargo Box - Safely
   / Moving Old Truck 20' Cargo Box - Safely #21
What "tools" do you have to work with?
3000 lbs is a lot of weight to some and nothing for other folks. If all you have is a lawn tractor, you have more work cut out for yourself.
This might be worth watching if you don't have much to work with.
Note how much less he used the jack to "move" once he found out it had a balance point to move the "rollers" from front to back.
Once I get the OK from my boss, we are going to use a wrecker service with a flat bed truck. I will post pictures when it happens. :dance1:
Got the OK, site is prepared - going to get the truck here tomorrow ......
   / Moving Old Truck 20' Cargo Box - Safely #24
Have the flat bed tow truck pull up behind it, level with the bed "box" and winch it directly onto his tow bed. Once at your place he can "tilt" his flat bed down and it should slide right off.
   / Moving Old Truck 20' Cargo Box - Safely #25
Take plenty of pics, because you know we all love pics.
   / Moving Old Truck 20' Cargo Box - Safely #26
Been there, done that!
Problems that I observed:
A truck 'box' is built on a steel rail that sits on the truck frame. That is 2" wide sitting on 2" frame so rolling or sliding the box off won't work as for sure the 'rail' will fall off of the frame.\I did consider welding side tabs to guide the slide off procedure but moving the distance I needed was also a problem.
What I ended up doing was to wrap a chain about mid point and jurry rigging a spreader bar at the roof level to prevent squishing the roof.
It just so happened that a decent sized excavator was handy and I hooked the chain on his bucket and he lifted and moved it to the desired (prepared) site.
The move took about 15 mins with absolutely no damage.
I had tied a rope so that I could steer and swing the box while moving it suspended from the excavator bucket.
That box (insulated) serves as my winter storage for my Toyota MR2 sport car. Being insulated was a bonus but I did make an entry and exit hole to circulate air by using a small fan.
Also no local tilt-n-load would take on the job.
Got working on this - cutting the bolts was a little sketch, they where under tension. I have 2 left to remove, those I have loosened up. Thanks to PILOON for the suggestion about the rails(see photos). I am trying to get this done next week. I think I have everything in order. Any other suggestions let me know.
Thanks for all the input
   / Moving Old Truck 20' Cargo Box - Safely #29
Another option like i posted with mine is rollers. Just user pipes and it made it easy for it to be pulled off
Got it DONE:cool2:
200$ and 30$ tip to the workers - Nice to have it on the ground safely - thanks to everyones input
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
More info coming soon! (A50322)
More info coming...
2018 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
ASV Posi Tool Backhoe Quick Attach (A51573)
ASV Posi Tool...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
Kubota Salt-Spreader (A52384)
Kubota...
