BX23 Battery Tender Connection Location
   / BX23 Battery Tender Connection Location #11
Last night I had to replace the battery in my BX2660 (the battery tender was not keeping the 8 yr old original battery up to par anymore) So while I installed the new one , I put the clamp on leads from the battery tender on the terminals too , and slid the battery in and checked and I see the clamps don't touch anything , and I drilled a hole in side of dashboard and ran the two prong plug out the side, now I can plug in tender anytime I feel need without having to pull the battery out to access the terminals. I hope my simple way works out. I can't see why it wouldn't by leaving clamps on . I guess I could cut the clamps off and put circle terminals and use the terminal bolts instead eventually.
Boy I would not just clamp them on. You won't know when a clamp comes loose or worse... short out something or get some chafing, etc. Put some eye or fork connectors under the terminals and forget about it.
Lazy man's approach: pigtail rings under the battery terminal bolts. Pigtail connector pokes out under the bottom of the battery/air intake screen.
Been that way for years on my BX24. Inelegant but it works.
Z.
The lazy man's approach was mine too until I got tired of having to reposition the wire a couple times while taking the console off and/or opening up the hood, depending on where I had the wire poke out.
   / BX23 Battery Tender Connection Location #12
I pretty much count on gravity to do the positioning :) The connector just sits there where I don't quite step on it.
Z.
1998 Ford F800 2,000 Gallon Water Truck (A52377)
1998 Ford F800...
JOHN DEERE/UNVERFERTH 1700/330 LOT NUMBER 13 (A53084)
JOHN...
2023 JOHN DEERE 8R310 LOT IDENTIFIER 188 (A53084)
2023 JOHN DEERE...
JOHN DEERE 560M LOT IDENTIFIER 37 (A53084)
JOHN DEERE 560M...
sod roller (A52377)
sod roller (A52377)
(1) 330 (1) 300 GALLON POLY TOTES (A51248)
(1) 330 (1) 300...
