Running Well Water Line in 2" Conduit
   / Running Well Water Line in 2" Conduit
I'm curious what the reason for the conduit is. Protection or some notion of easy future replacement?
To protect the PEX and power wire for the well pump. Lots of boulders/rocks in the soil so the grey rigid 3" PVC Sch40 conduit will protect it.
I will try the 3" rigid PVC Sch40 conduit so that should give me more room to navigate inside the pipe
   / Running Well Water Line in 2" Conduit #22
Different situation but same idea. The big 'ol buried copper cable bringing power into the house is inside plastic conduit. Local code requires this. As explained to me - one of the major reasons is to keep pocket gophers/mice from chewing on unprotected power cable.
Our local codes dealing with utilities separation speak mainly to the water line & sewer line. There is horizontal and vertical separation required. As I remember its two foot horizontal separation and the water line must be one foot higher than the sewer line, if both are in the same trench.
   / Running Well Water Line in 2" Conduit #23
...It is also a bad idea to run a water line inside a bigger pipe because of the movement of the water carrying pipe inside the conduit...
Eddie is absolutely right on this. If a plastic water line is not restrained it will flex and move when the water flow is started and stopped. This rubs the water line against the inside of the conduit, always in the same places, and leads to early failure.
If you burry the plastic pipe directly in the ground the earth prevents this movement and the pipe lasts longer. If you are concerned about rocks, put a layer of sand in the trench below the pipe and after you put the pipe in, backfill with more sand. This cushions the pipe while still preventing it from moving.
   / Running Well Water Line in 2" Conduit #24
Out here they do that ALL the time and code officials are perfectly OK with it. They actually allow you to drop PEX and the power wire directly into a trench, no conduit, sitting on top of each other.
Why is it dangerous?
If you think about it, the well pump wire is sitting inside a well with a 100+ feet of water surrounding it.
The movement of the PEX is almost non-existant. PEX sits inside floor slabs and inside walls, near live power wires. No code violations.
From what I understand, the reason for separating power and water in separate trenches has to do with injuries that happen when trying to repair a broken water line and having to dig it up with an electrical line close to it.
Water lines move all the time. Turning the water on and off creates a surge. This is why they are supposed to be anchored inside the wall cavities. When PEX or any other water line goes through the slab, it needs to be wrapped in something so it doesn't wear itself away. Most common thing to use is foam pipe insulation around the pipe before pouring the concrete. Drain lines don't surge, so they don't need to be wrapped. Same with conduit for power. But water lines definitely move a lot.
Unprotected PEX sitting in the native soil is subject to moles, gophers, boulders, rocks, etc.
If the PEX is sitting inside a 3" plastic smooth conduit, it is protected and I don't see it being less safe than being dropped into a dirt trench. Even if the water surge kicks, it is not rubbing against anything that would damage the PEX.
Also, if I ever need to remove the PEX water line, it can be pulled out through the conduit without having to dig it up. That is NOT possible with a direct burial into dirt.
   / Running Well Water Line in 2" Conduit #26
I've heard of diseases and pregnancies and I knew rocks and bolsters can be a problem doing it on the soil but never heard of moles and gopher problems. YIKES!
I decided on 2.5" conduit since the 3" is not in stock at the big HD store. The 2.5" should be more than adequate to push 1.25" PEX & a flat submersible well pump cable through.
Someone said to go with a 3/4" or 1" main PEX line from the well to the house but when I did the online calculator the drop in volume resulted in a large drop in PSI. The 3/4" line was the worse with almost 30psi loss at a 75' run.
Spend a little extra for the 1.25" and that will keep the pressure drop from happening and provide a little extra volume in the system.
   / Running Well Water Line in 2" Conduit #29
Would you believe I pushed about 150' of 1/2" pex inside 3/4" black poly tubing? I was surprised how easily it worked. Squirted a shot of wire-lube into the tubing before I started.
   / Running Well Water Line in 2" Conduit #30
Black ploy can work well, the long sweeping turns and slick nature help.
2014 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2014 UTILITY VS2RA...
UNKNOWN  SPOOL TRAILER (A58216)
UNKNOWN SPOOL...
2024 CATERPILLAR 305 CR EXCAVATOR (A60429)
2024 CATERPILLAR...
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
WATER TRAILER (A58214)
JCT 48" HYD TRENCHER (A52706)
JCT 48" HYD...
