Ford F150-I'm Done.
   / Ford F150-I'm Done. #261
   / Ford F150-I'm Done. #262
According to KBB, trade in value is about $10K. I can't see spending $10K+ on a new engine. It is driveable at least to a dealer I think. What a friggin' headache. Only 80K miles!!! Been a ford guy for a long time. Wavering now and have no clue what to do. Comparable new ones are north of $50K!
Good luck with whatever you choose.
My Son buys trucks in this condition off the dealership back row and fixes them. Makes a good second income out of it. The dealership is totally gonna rape you in a trade...... :(
   / Ford F150-I'm Done. #263
Sorry to hear that.
First I'd want a second opinion...
Then, I'd find a custom garage and check on a rebuild price. I'm sure they can repair or rebuild, probably build you a stronger engine anyhow, for half the cost the dealership wants.
Yes, second opinion I agree. Firestone is a tires and brakes place in my mind. Doing lots of research on line. Cam Phaser issues keeps coming up. $2500 but problem might come back.
Was there any reason for this to happen such as running out of oil, being in accident, etc..?
No... a little low on oil when it happened. No accidents.
Includes install, they said that was max price but depending what they can reuse the price will be less. Yeah need to shop it if I go that way.
Do your truck have variable valve timing? My Merc did that at 80k and we took a educated chance and replaced 2 sensors and it worked.
Looking on line, looks to be a cam phaser thing but now there are chips in the engine oil.
   / Ford F150-I'm Done. #265
I'd have an independent shop put an engine in that F150. Summit is usually high because they focus on performance products. A quick look around the internet indicated rebuilt 5.4 Liter engines are around $2500. A shop will want to make a little profit on the engine and then there is labor and odds and ends, but $4000 to $4500 might get you there.
   / Ford F150-I'm Done. #266
That seems more reasonable. This was starting to look like the cost of a diesel engine.
   / Ford F150-I'm Done. #267
Thanks... probably best option as truck is in great condition otherwise. Wondering if I should drive it home at this point?
   / Ford F150-I'm Done. #268
If yours was a higher end trim level 2006, it should have been worth more than $10k having only 80k miles on it. Even if it was a higher trim package, there are a lot more options available on the lower trim models than was even available in 2006. A $50k model 2016/17 is going to be a top tier trim and have bells and whistles that weren't even thought of in 2006 along with pretty drastic capability/performance increases. To call anything from 2006 "comparable" to a new $50k truck isn't really reality. A 'nicely equipped' 2016 XLT off the lot for $36k will even have things that were only top tier options in 2006.
The base engine in 2006 was a 4.2L V6 with 202HP and 260ft/lbs of torque.
Your 5.4L V8 put out 300HP and 365ft/lbs of torque.
The base engine in 2016 is a 3.5L V6 with 282HP and 253ft/lbs of torque.
The 5.0L option for the 2016 has 385HP and 387ft/lbs of torque.
Anything the trucks of yesteryear could do, the trucks of today can too. Those worried about handling a load, don't need to be. The 700lbs weight savings they talk about really doesn't put it into perspective for me. The best comparative example I've seen says the heaviest, largest, most feature laden 2015+ is 200lbs heavier than the lightest, smallest, most basic 2014 that was built. That 700lbs wasn't much. Then take into consideration the lower center of gravity from the lighter body work, changes in frame design, setting the engines down farther between the frame rails, all this leads to extra stability.
After having over 28000 miles under my butt in mine, I'm still impressed by all of the innovations of the past 10 years, as well as the thought that went into most of the implementations of those innovations. I came from a 2006 Ford Ranger XLT that I paid just under $20k for when new, into a 2015 F150 Lariat that I paid less than $40k for, also new.
   / Ford F150-I'm Done. #269
The new 3.5L in the 2017 addresses the carbon buildup on the intake valves common to all direct injection engines of every stripe with a combination of port injection (that will clean the carbon off) and direct injection. It also fixes an uncommon problem of the seal on the high pressure fuel pump failing and dumping fuel into the crankcase. Drill a 1/16" hole at the lowest point in the intercooler and the new engine should be better than the 3.5L ecoboosts from 2011-16.
Chain stretch wise for the older 2011 EB engines, increased oil change frequency should keep that problem at bay.
I've added a huge catch can to stop the crankcase vent system from dumping oil vapor into my intake system that hastens the carbon build-up on the intake valves and causes misfiring.
   / Ford F150-I'm Done. #270
I got the 3.5L ecoboost in my 2015 too. Rather than modifying it I just got enough warranty to cover me when they need to replace the heads later down the line.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2003 Pierce 75ft Ladder Fire Rescue Truck (A55852)
2003 Pierce 75ft...
2013 Ditch Witch XT855 Tracked Loader (A56438)
2013 Ditch Witch...
48" Pallet Forks (A59814)
48" Pallet Forks...
2022 KOMATSU D71PXI-24 CRAWLER DOZER (A60429)
2022 KOMATSU...
