Cold weather starting and idleing?
   / Cold weather starting and idleing? #1
devildog1
Up-State New York
Grand L 3540 HST-3, R4's
I always thought you should start you vehicle and let it warm up until a this on PC today. Your thoughts?
DevilDog
[FONT=&quot][/FONT]http://www.msn.com/en-us/autos/ownership/warming-up-your-car-in-the-cold-just-harms-the-engine/ar-BBxuI1d?li=BBnb7Kz&ocid=HPCDHP
   / Cold weather starting and idleing? #2
The article is true. That's what I do in winter. Start the truck, clear the snow and ice (takes about 5-8 minutes) then get in and take off.
I start my tractor the same way for plowing snow. I check the oil, then start it and get in and go. My tractor is kept in the garage and only gets a couple minute warm up before I go. I plow at slow RPM (about 1500) for about 10 minutes then bump up to 2200 RPM. Heat is usually blowing by then and temp is in normal range.
   / Cold weather starting and idleing? #3
[ I always thought you should start you vehicle and let it warm up until a this on PC today. Your thoughts?
DevilDog
I usually follow the instructions in the owner's manual.
   / Cold weather starting and idleing? #4
The link didn't work for me, but I'm a warmer upper my self and don't see how warming a vehicle up would hurt a thing but the "greenie's" imagination. Tractors & other basically hydraulic machines I give an easy 15-20 min. in the real cold. I just picture a .10 cent o ring, of which there are many, hard as a rock failing in the cold. How many internal plastic parts are in today's machines & vehicles? You know what plastic does in the cold!
   / Cold weather starting and idleing? #6
Thanks George, but I'm stickin to my warm up. There's a whole lot more than just the cyl. walls to be concerned with, at least in my little brain:D My pickup is closing in on 7000 hours. Oil & filter changes only, but prolly 100 hours of warm up time:laughing:
   / Cold weather starting and idleing? #7
Only about 3200 miles on my truck. As I said, if I'm going somewhere I only give it enough time to clear the snow and ice then I go. If I'm not in a hurry I do hit the remote start which runs for a full 10 minutes so it's nice and warm when I get in.
With the tractor in the garage it doesn't get below 40 deg. so a couple minutes is good enough before moving it.
   / Cold weather starting and idleing? #8
10-4 on the heated garage! The only thing is that the snow sticks to the 60* plow for the first 10 minutes or so. What a problem to have right?:laughing:
   / Cold weather starting and idleing? #9
I don't know how you're supposed to drive safely when your windshield is frozen over and you have no defrosters because your engine is cold. I think whoever wrote that article never drove in winter weather.
   / Cold weather starting and idleing? #10
Just may be.
2848 (A58376)
2848 (A58376)
Hays LTI PTAT180RD Seed Tender (A57148)
Hays LTI PTAT180RD...
John Deere 4820 Forklift (A57453)
John Deere 4820...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2015 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2015 UTILITY VS2RA...
Ford 8340 (A53317)
Ford 8340 (A53317)
