I remember using a chain saw on pulling tires. Used to be the way to do it.
I think whether they are successful or not is dependent on expectations.
Well in that case, I'm golden.
In all seriousness, I'm sure that the placebo effect plays into it. Furthermore, I don't claim any immunity from it. That's a big part of why I didn't want to spend $100 on a grooving iron. I'm not expecting a dramatic traction increase. But hey, I've got less than a half an hour into this project. I don't think it'll make anything worse, and might make things a little better. Even if it's only in my mind.![]()
Definately an improvement over stock R4: whether that's good enough, YMMV.I think whether they are successful or not is dependent on expectations.
If you THINK you went through that drift and up that hill, you DID go through that drift and up that hill.
Bruce
Quantifying the results would be hard to do. Soooooo many variables involved.![]()
You won't need to qualify them. They're so much better you will want to forget the old slicks slip-sliding non stop.
I rarely use 4x4 in the snow now, and before I couldn't move in just 2wd. Thats with 1,000lbs ballast on the back and FEL on front.
