Hydraulic Cylinder Leak Down on Box Blade???
   / Hydraulic Cylinder Leak Down on Box Blade??? #61
Wow. So he's probably done nothing to fix his problem?
Maybe. Did he replace the gland seal? I don't know?
Sorry I didn't put a ? At the end, but you never answered my question at the end of post 57. What do you think his issue was?
   / Hydraulic Cylinder Leak Down on Box Blade??? #62
I have no idea. I make no claims to know. Do you? :)
   / Hydraulic Cylinder Leak Down on Box Blade??? #63
Why would he replace the gland seal?
   / Hydraulic Cylinder Leak Down on Box Blade??? #64
Something to keep in mind is that a faulty piston seal will create a pressure intensification on the rod side of the cylinder if the weight is trying to retract the cylinder. This higher pressure may cause oil to bypass a valve spool that wouldn't leak much under normal circumstances. Not saying that was the case here, just something to keep in mind.
   / Hydraulic Cylinder Leak Down on Box Blade??? #66
Maybe I missed something in this thread but I recall Piston said his box blade was leaking down........in his pics of the unit it shows his cyl is a pull cyl, so that to me would mean his cylinder rod is drifting out when the box blade is "leaking down" (his words)......He never said the cylinder was drifting in (IIRC)
The same setup as most bucket/tilt cylinders on FEL. If the piston seal or a check ball was not pressure tight on the piston head it would drift out like Piston said......so Yes his problem was directly the check/valve ball if it was off the seat......maybe that curl was a piece of a spring that got mashed between the hyd rod and the cyl base
   / Hydraulic Cylinder Leak Down on Box Blade??? #67
I thought the same thing too when i watched the video. But post 9 and 10 clear it up better and I think Piston did say somewhere that the cylinder does indeed retract when the rippers drift down.
There is a linkage in there that makes the cylinder retract when the rippers drift down. The cylinder extends to raise the rippers. SO this would be just like loader arms drifting down.
   / Hydraulic Cylinder Leak Down on Box Blade??? #68
Yep, missed that pix......I was thinking it was the top cyl lifting the whole box blade
Wd,
I did say what you wrote, but I made a mistake. When the scarifier bar would bleed down, the actual cylinder was retracting, so bleeding "in".
On this box blade, in order to raise the scarifier bar, you fully extend the cylinder. And in order to lower the scarifiers for ripping the ground, the cylinder is fully retracted.
I wasn't going to post anymore because this thread seemed to take a turn, but it seemed you were genuine in your reply. Thank you.
   / Hydraulic Cylinder Leak Down on Box Blade??? #70
Hydraulic Cylinder Myth - Exploded!
This is some good info on what happens when the piston seal leaks. I realize that a leaking piston seal was not the culprit in this thread but thought some might be interested nonetheless.
2019 CATERPILLAR 308 CR EXCAVATOR (A51242)
2019 CATERPILLAR...
2018 Chevrolet Tahoe SUV (A50324)
2018 Chevrolet...
2011 Chevrolet Malibu Sedan (A50324)
2011 Chevrolet...
2022 CATERPILLAR 259D3 SKID STEER (A51242)
2022 CATERPILLAR...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
2012 VOLVO DBL SLEEPER ROAD TRACTOR (A51243)
2012 VOLVO DBL...
