What did you do at work today?
   / What did you do at work today? #11
Thought of doing some work last week. Haven't got to it yet...
Welded some grips on the fingers for a robot on some AR400 plate that was water-jet.
   / What did you do at work today? #13
Removed the Injector Pump and starter from my 3910. Pump will be rebuilt, leaking diesel. Starter solenoid requires 3 or 4 hits before engaging.
Who has time for retirement.....
Not sure where you live in MO but a guy on Jackson MO fixed a leak in the top of my pump for $75 without having to rebuild it.
   / What did you do at work today? #14
We've got a good small shop locally. Where mine is leaking he has to disassemble the pump to fix it. So he'll put a kit in it replacing all the seals and gaskets. Even then, it'll probably be $200 or so. Said it depended on what he found. Hoping for good news. Thanks for the tip though!!!!
   / What did you do at work today? #15
Used the CMM this morning to help a supervisor get a couple of parts up and running for a big customer. Ours has been an abrasive relationship since I started here. However, getting him the info he needed for adjustments in about 2 minutes seems to have softened him a bit. He even thanked me (that's a first).
CEO brought around paychecks already today, too. I'll call this a good day.
   / What did you do at work today? #16
Keeping low profile..to much b.....ing going on. :rolleyes:
   / What did you do at work today? #17
That was my gig for 30 years. DEA, Sheffield, Mitoyo, but mostly Zeiss.
Maybe stick with welding? :)
You say that cause I threw the piece out of the mill yesterday? lol. I love running the milling machine, I been welding for 31ish years and I get burnt out on it pretty quick.
The Woods bush hog I bought has a baler belt on the front of it as a guard, it's torn up. I was looking thru the manual and found a picture of a chain option. I started working on that. We don't have any fab machines to break or bend so I am going to make it angled with a plate and piece of angle iron. I started cutting slots and got one done. The guy at the hardware store is going to flip out when I tell him I need him to cut me 56 pieces of 5/16" chain 7 links long, lol.
2014 Ag Spray Schaben Sidedresser (A56438)
2014 Ag Spray...
HOBBS 48FT FLOAT (A55745)
HOBBS 48FT FLOAT...
Case IH MX270 Tractor (A59814)
Case IH MX270...
2007 FREIGHTLINER M2 26FT BOX TRUCK (A59575)
2007 FREIGHTLINER...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
(APPROX. 20) 4' X...
