Couple of Harbor Freight QH questions
   / Couple of Harbor Freight QH questions
OK thanks for the warning. I will continue to use the flex link when using the cutter on the QH. Sounds like the safe thing to do.
   / Couple of Harbor Freight QH questions #62
You only need that top link to lift the mower, not when mowing. So chain is sufficient.
Very true. I had a hydraulic toplink & left it in float giving me lots of articulation. The toplink moved slow so I'd leave the flex link there. I moved the top hook to the bottom holes & would just flip the flex link into the hook. I think most people reconfifure things so it flexes behind the top bracketed when using a quick hitch. I just left the 6" flex bit in front dangling.
It would just pop out if the hook was any higher. It would actually pop out down low every so often. I wouldn't bother fixing it until I needed to road the machine or hang the mower over a ditch or something. I'd run it like that for hours with no ill effect.
If someone gets a chance, please post a picture of how to chain a rotary cutter as an alternative to the flex link.
Fallon, could you explain what you mean by saying you leave a hydraulic top link in float. I have a HTL, but unfortunately I'm not totally understanding your last post.
   / Couple of Harbor Freight QH questions #64
   / Couple of Harbor Freight QH questions #65
I'm home in town so this ballast photo is the closest picture I have available. I use this chain to reach back and make a slack loop over the top of the mower's 3-point mast. And unpin the hook to swing it up out of the way. That's all there is to it, the slack chain loop is sufficient to go tight and raise the back of the mower when I raise the qhitch.
Next time I have the mower attached I'll take a photo but it's going to be a while. 5 to 15 inches of rain forecast for the next couple of days!
390836d1410972768-po-boy-ballast-box-kimg0243rqh-ballast-jpg
   / Couple of Harbor Freight QH questions #66
Good Idea!
   / Couple of Harbor Freight QH questions #67
My L3200 had a float detent for both top & side links. Just like your loader lift circuit. Put the valve in float & it would extend or retract as anything pulled or pushed on it.
To chain a rotary cutter just attach a piece of chain to the toplink bracket on the cutter then attach the other end to the tophook. Leave 6-10" of chain between. It just needs to be short enough so it will tighten up & lift the tail wheel off the ground when you lift the cutter.
I did not know that TnT cylinders had float capability. How do you activate and deactivate?
I did a little research last night. Learned that the float capability, or lack thereof, is a determined by the remote valve. Some have it some don't. My property where the tractor stays is a couple of hours away so I can't just go out and take a look. The lever that controls my one remote always returns to the neutral position after I activate it in one direction or the other. Best I remember, there is nothing in the lever area to indicate float capability.
The cylinder on my HTL does leak down after a period of time with a load, i.e., when i tilt the rotary cutter up, it will leak down until the tail wheel touches the ground. That indicates to me that the remote operating the HTL is in float. Any thoughts?
   / Couple of Harbor Freight QH questions #70
Leak down is normal & just indicates your valve isn't perfect. Some TnT cylinders have check valves on them to prevent leak down. Those check valves have the side effect of disabling float even if your valve supports it.
2015 FONTAINE TRAILER CO. 53 STEP DECK SPREAD AXLE (A50854)
2015 FONTAINE...
1993 Ford Ranger STX Ext. Cab Pickup Truck (A50323)
1993 Ford Ranger...
2005 WINNEBAGO WORKHORSE W22 RV (A50854)
2005 WINNEBAGO...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2019 Allmand...
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
2007 HYDRO-AX 764 MULCHING MACHINE (A51242)
2007 HYDRO-AX 764...
