Chain saw sharpening advice sought
   / Chain saw sharpening advice sought #71
I sharpen mine using a wall mount electric grinder from Tractor Supply. However, I had to modify it to get satisfactory results. There was too much slop out of the box, which caused inconsistent tooth length, and hence the chains would cut on a curve. The 16"-20" chains were ok, but the 36" bar has to be spot on or you'll have to fight it through the wood.
It seems like with my luck, the chains stay pretty sharp until I hit something. I can't imagine having to file a 36" chain by hand after hitting dirt or a nail and getting decent results. If I get the rakes and teeth ground correctly, I can get the chains to cut like new.
My longest bar is 32". I hand file that but it is skip tooth so not many more teeth than a regular 20". If I "really" rock a chain it is either pitched to taken to a dealer to be sharpened on his grinder knowing that it will probably come back with blued teeth and too hard to ever file by hand again.
   / Chain saw sharpening advice sought #72
I would suspect it's more difficult to get a consistent tooth length and angle, and rake depth using a file compared to a jig on a decent sharpener. The minor discrepancies will be less of a concern on a shorter chain, and also less of a concern if it's just a touch-up sharpening.
Before I bought & modified my current sharpener, I used a few of the cheaper sharpeners from Harbor Freight and Tractor Supply.....they were ok for the smaller chains but didn't work at all for the big stuff.
I just eyeball the tooth length on each side, eyeball is close enouth. If they are different I add a stroke or two on the long side.
   / Chain saw sharpening advice sought #73
One of the most important things I have found is consistency. With practice you can get good pretty quick, whether you use a guided file or do it by hand. The issue I have found with powered sharpeners like the harbor freight are that the chain holder isn't that sturdy or precise so you get inconsistent angles and depths. The test of how good you are is the chips that come off the chain when you run it. Nothing else matters. I have heard arguments about angle, technique, and a bunch of other things that are "internet important." I have played with angles and techniques but have settled on an Oregon manual guided bar mount that does pretty good. I get chips off ponderosa pine that look like I was using a plane.
I also use the Oregon file guide, do chains from 14" loops to 32" loops. Nn problem at all with crooked cuts except occasionally I will make a mistake and get a crooked cut. No biggee, just swap it for one of the spare chains and correct the bad one next time I file it.
   / Chain saw sharpening advice sought #74
If I cant plug it in, I dont like using it, this is one of many power sharpening options>> How To Sharpen A Chainsaw Properly - YouTube <<I have this one and think it does a good job for the money. Probably the grinding wheel version would be faster, but the only grinding wheel stile I'd consider is the kind where the bar can stay on the saw, not a fan of taking chains off the saw until it's all used up.
   / Chain saw sharpening advice sought #75
I used to hand sharpen for years and years and then I got a grinder machine. It's just easier and super fast, and I like being able to set one consistent angle and depth and have all the teeth the same. Obviously there are many ways, hand being the easiest if you are in the field as well. Like the other posters said, if you machine sharpen, don't overheat the teeth.
Oldpath05, thanks for the info and the video link. You have changed my mind. After watching that video and a couple of other videos demonstrating that sharpener, it is what I have ordered. This will make the sharpening angles and pitch consistent, will be fast, and can be done with the chain on the saw. And because it operates off of a 12 volt battery, it can be used in the field.
BTW, a much better video re the device is:
Granberg G112XT 12 Volt Chainsaw Chain Sharpener/Grinder - Bing video
This video is much more detailed, and shows the set up and adjustments much better and actually is more correct re the set up (in the other video the device is not quite used correctly.) Anyway, after considering just about every option possible, this is the best fit for me Thanks again. Once again this forum has solved a problem for me.
Note: I could not find this item (Grandberg G1012XT 12 volt) on Amazon or anywhere else locally, but found that I can order it directly from Grandberg.
   / Chain saw sharpening advice sought #78
A couple things, one, depth gauges aka rakers are easy. You need to lay a straight edge across the top of each set of two cutters and see how far below that the raker between them is. .025" is what you want. A caliper works for to measure, but after a few times doing it, it's easy enough to eyeball. A Carlton File-o-plate is the best for determining where each raker needs to be, but they're out of production.
Rakers are easily taken down with a flat file, but I prefer a dremel with a sanding wheel or stone. Much less hand cramping.
Lastly, if you don't already grease you bar sprocket, you don't need to start now. Oregon says they do fine with just bar oil lubrication, and that greasing through the hole can actually force grit and grime into the bearings. Some people grease, some don't. I never have, and haven't ever had as problem.
I concur with that post.
   / Chain saw sharpening advice sought #79
Wow! Don't think I've ever seen a chain sharpened to the point of having the teeth as short as that Granberg video! That one is to the point of the trash bin in my book, but obviously will still cut well!
Since you have a bunch of old, probably well-worn chains, I think you will be happy with the power grinder. Manual filing of really bad teeth, even with a sharp file, gets tedious after one or two chains worth.
The Granberg looks terrific - it duplicates exactly what I do freehand with a Dremel. Just still be careful to not use too much pressure for too long such that you overheat the teeth.
Oh, and regarding the chain cutting straight through a log - I'm not convinced that this is solely because of uneven tooth lengths. I have sharpened chains where a couple of teeth have been badly damaged by hitting barbed wire, so required grinding down shorter than others. The chain still cut just fine. I think that consistent "hook angles" between the teeth on opposite sides is more critical, and the Granberg should ensure that.
I was thinking the same thing about the short teeth as I watched the video. I really liked the video tho, great detail and lighting and camera closeups and focus really made it easy to watch - and he was very thorough.
Thanks for the tips. I can't wait until it arrives and I can start sharpening - even tho with all the rain we have been getting it will be a while before I get to any of the sawing tasks.
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A52706)
2018 GENIE...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2017 Caterpillar 326FL Hydraulic Excavator (A55787)
2017 Caterpillar...
2013 Nissan Rouge SUV (A55758)
2013 Nissan Rouge...
ASSORTED NYLON SLINGS (A54757)
ASSORTED NYLON...
COUNTER WEIGHT (A54756)
COUNTER WEIGHT...
