Track Tensioner won't take grease. What do I do ?
   / Track Tensioner won't take grease. What do I do ? #41
Button head grease fittings may work with high pressure.
[video]https://www.google.ca/search?q=high+pressure+grease+fittings&client=safari&hl=en-ca&prmd=isvn&source=lnms&tbm=isch&sa=X&ved=0ahUKEwicqO62xqbRAhVm1oMKHc2CD3oQ_AUIBygB&biw=1024&bih=648#imgrc=ODhMqaeBSeub-M%3A[/video]
Sounds like the grease is dirty and it has become solid. Did you try spraying brake cleaner inside the opening and then digging around in there with something small?
After doing a really good cleaning of the inside opening, and letting the brake cleaner soak into everything it can for awhile, I would get all the weight off of that track by lifting it off of the ground with the boom. Then try it again.
Basically, there is only two things going on in there. Grease is pumped in until it forces out the cylinder to tighten the tracks. And the seals around the piston hold the grease back so that the tracks remain tight. Since you cannot get grease into there, we don't know if it's the seals or not. Just that the grease is dirty, solid and not going anywhere.
Thanks Eddie. I am going to spray it out next chance I get. I am also going to clean the frame and tracks up a bit as Citydude mentioned. Want to make sure it isn't just caked on, dried mud that is causing me a problem.
   / Track Tensioner won't take grease. What do I do ? #43
Try removing the zerk and or maybe a pipe plug from cylinder . Pick up that side and run the track . It should collapse some and maybe loosen things up . Might force out some of that dried out gunk .
   / Track Tensioner won't take grease. What do I do ? #44
$2.75. A little steep but the exact size I need. I will pull the other one, attempt to clean it and reinstall it. If it works, I will just put this one in my took box. If not, I will swap it for this one and hopefully that will resolve the issue. I am also ordering a large assortment of zerk fittings to keep up there.
The grease fittings have a proprietary thread pitch, standard metric ones will not thread in correctly.
What's likely happened is rust has built up in the track adjuster and that's what's not allowing it to take anymore grease. Or you have run out of travel on the adjuster and the grease is leaking out the end. Track adjusters are just like hydraulic cylinders except they lack a piston to retain the rod in the barrel so if you were to remove the adjuster you can pull the rod right out to clean the barrel out, the hard part is getting the track off.
We usually hook a portapower up to the track adjuster in an attempt to free them up.
   / Track Tensioner won't take grease. What do I do ? #45
Sometimes, if there is uneven wear between an axle and a hole, which an axle turns in, an axle may block the passage of grease. A zerk replacement could make no sense. In such case you just need to change the position of axle (while turning it in a hole) so to unblock a grease passage. And it works. That's from my experience.
I spent some time today studying the diagram of the track tensioners I found online. When I get back to the farm next weekend I will be looking at it.
   / Track Tensioner won't take grease. What do I do ? #47
Or, in your case, you just need to loosen up a tensioner, and it could take in the grease. That costs not much resources.
   / Track Tensioner won't take grease. What do I do ? #48
When all else fails:
Some folks tension the track by other means, like a chain attached to the dozer blade then when lowered pulls the track tight and thus extending that loose leaky tensioner cylinder.
Then they fabricate a shim to keep the cylinder mechanically extended.
Usually the shim is a pipe withe the same ID as the tensioner shaft'
They slit the pipe shim in half and simply clamp the two halves with hose clamps thus having it permanent and no longer adjustable.
Naturally the shim is trimmed for tight length fit.
This technique is often seen on 'dozers that are nearing undercarriage 'end of life'.
   / Track Tensioner won't take grease. What do I do ? #49
That is how I made the "stroke stoppers" for my TORO+Loader. :thumbsup:
2015 GREAT DANE ETL-1114-31053 REEFER TRAILER (A54607)
2015 GREAT DANE...
SET OF (4) BRAND NEW CHAINS AND BINDERS (A53843)
SET OF (4) BRAND...
JOHN DEERE 1725 CCS (A53084)
JOHN DEERE 1725...
LOAD OUT INFORMATION (A53084)
LOAD OUT...
2015 PETERBILT 367 (A53843)
2015 PETERBILT 367...
SET OF (6) LADDERS (A53843)
SET OF (6) LADDERS...
