Anyone know if angle iron like this with holes in it is available?
Anyone know if angle iron like this with holes in it is available? It's probably 1/4" or 3/16" thick and this sure looks commercial to me. It sure would be helpful for a project I have.
Make you a Jig that drills maybe 10-12 holes that will set up against the back leg and then get busy with a very good drill and a drill press. It will go quicker than you think and will be Waay faster than tryin' to track down pre-drilled material. bjr
Steel Angle Iron - Buy Online at SteelFront is this what you are looking for?
I Have drilled holes before on similar projects but just trying to avoid the work. Guess I'll wind up drilling.
Tell us more about your project, then maybe we can think of alternative ways to do it.
Bruce
I've built many light cultivator type attachents and usually can scrounge old Ferguson/Dearborn frame piece already drilled. This time around, I'm building a grass dethatcher type tool that will be around 8' wide and need 96 holes in probably 1/4" stock. That's a lot of holes and I was just hoping someone knew of something that might be newer on the market. You never know.
Find a steel shop with an iron worker and it would take 10 minutes to punch all the holes you wanted.
