OP
sixdogs
Super Star Member
- Joined
- Dec 8, 2007
- Messages
- 13,855
- Location
- Ohio
- Tractor
- Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
What about using a Land Pride Spike Tooth Harrow? Spike Tooth Harrow will give you considerable 'reach' under trees.
LP STH15has one spike for every 1-3/4" of coverage. Note: 10 settings for tine angles.
STH15 Series Spike Tooth Harrows | Land Pride
Of a common Landscape Rake? Landscape Rake will have more ground contact, however you could remove every-other rake tooth.
Or consider a suspended Chain Harrow. The one I assembled has 1/2" chain. For commercial use I would use 3/8" or 1/2" chain. Suspended, you could scuff under trees.
http://www.tractorbynet.com/forums/...c-countyline-tarter-boom-pole.html?highlight=
I have tried multiple kinds of spike tooth harrows including one I built special for the purpose. None of them worked because they plugged with dead grass, ripped out too much existing grass and created divots. I had to stop frequently to unplug them. Plus, where there were chunks of sod from ground I had worked, they would drag those chunks of sod or even clumps of dead grass and screw up the beautiful work I had already done. They work great on dirt with no grass, however.
Landscape rakes are too smooth and ride across the surface. If you ever get into worked ground they will drag along clumps of everything and make a mess. I have enough work without adding to things.
No dice with chain harrows, including suspended ones. They plug in 5 minutes and took a half hour to unplug. Ugh.
Vibrating tines work because I have seen it. I don't wan to make federal case out of making one but if I can stumble aross some parts and the right tines, I'm going to make one. The storebought one I showed a photo of earlier is almost $5,000 and that is not cost effective for what I want to do with it.
