Please Double Check Me Optioning and Pricing a B2650
   / Please Double Check Me Optioning and Pricing a B2650 #1
Milo
Preston County, WV
JD 3520, Ferris Z2100, Kawasaki Mule Pro MX, Honda Pioneer 520
I've narrowed it down to a B2650 with turf tires, 72" mmm, FEL with QA 60" bucket. It will be used for mowing (a lot more than I do presently), driveway maintenance, moving of brush, trees, and rocks, and a couple small fields as well as trail cutting a couple times a year. Near future purchases will be a grapple and flail mower with hydraulic shift so I'd like to have the correct rear valve kit and front 3rd function pre-installed. I'll keep my current rear blade and ballast box. In addition I'll ask them to weld a hook on the bucket. I built it on Kubota's site and would like to know if you see I missed anything or have something wrong? Sorry that I couldn't copy over the prices in a straight column.
Kubota is now showing $1,000 incentive or rebate. ($500+$200+$300) minus whatever discount a dealer will offer, hopefully 10% or so.
1 B2650 with FRONT - 24x8.50-14 R3 Titan Multi Trac REAR - 13.6-16 R3 Titan Multi Tracinc. $16,650
1 1ST POSITION DOUBLE ACTING VALVE KIT $795.00
1 FRONT LOADER PACKAGE $3,208.00
1 MECH 2 LVR QUICK COUPLER $432.00
1 60" LIGHT MATERIAL QUICK ATTACH BUCKET $559.00
1 3RD FUNCTION VALVE KIT FOR ROPS $799.00
1 72" MID MOUNT MOWER $3,593.00
1 RATCHETING LIFT ROD KIT $113.00
1 TELESCOPIC LOWER LINK KIT $208.00
Total list price $26,357.00
   / Please Double Check Me Optioning and Pricing a B2650 #2
Looks like you have all the bases covered.Go with the lightest grapple or just add a "thumb" to your existing bucket and make it removable when not being used.
Thanks nybirdman. It will be a lightweight grapple.
Re: Please Double Check Me Optioning and Pricing a B2650... Update on Order
Since I started this I sold my B7500 and yesterday ordered the B2650 with below options plus added second rear remote, one to have float function $369. Also front suitcase bracket with (5) 55# weights for $488, which increased msrp to $27,024.:eek: After rebates and discount $23,644 delivered, I'm satisfied. Now broke and happy I'm anxiously waiting. :D
A grapple will be ordered by Spring, leaning toward EA 50".
   / Please Double Check Me Optioning and Pricing a B2650 #5
You will love the 2650, we do.
   / Please Double Check Me Optioning and Pricing a B2650 #6
Congrats on your new tractor. Price is good for all the options you got. You got it set up with all the toys a person could want!! Great job. I have over 540 hrs on my 2015 and it has been flawless. Enjoy.
Thanks guys, I think it'll be just enough of an upgrade over my previous tractor to do what I now will need w/o being too large and heavy.
Ih782 you sure have a nice stable of tractors!
   / Please Double Check Me Optioning and Pricing a B2650 #8
Ask your dealer, but I think the B2650 comes standard with telescopic lower links and ratcheting lift rod. I did not pay any more for them on my b2650. The brochure at the time I bought mine said it was included. The second rear remote with float detent is a great idea. I use a hydraulic toplink with my flail and it follows the ground contours perfectly. I mow 10 acres and it looks like it is finished mowed but pretty rough ground in some spots.
Both in the brochure I have, as well as building it on Kubota's site, telescoping lower links are optional for $208 and the ratcheting lift rod a $113 option so I asked them to be included in the quote. (Pin type telescoping stabilizers are standard.)
Thanks for the encouragement buying the extra rear remote with float, I think I got the advice from someone here on the huge flail mower thread. I'm trying to decide whether to order a flail or put that money (and a lot more) toward a good Zero Turn. I'll be mowing about the same amount as you and much is rougher than a lawn, what flail do you have and what blades are on it, "Y" cutters? The flail I was considering is Peruzzo Fox-S 1600, 59" cut with hydraulic side shift.
Iowa Farm Equipment -- Peruzzo Fox S Side Shift Series Flail Mowers
   / Please Double Check Me Optioning and Pricing a B2650 #10
I have a McConnel Magnum. Flail mowers
It has cast brush hammers that are quite heavy. Does a great job on both small trees, large weeds and vines but also finish mows lawns almost as good as a zero turn.
2017 Mower Max Flexwing Mower (A51573)
2017 Mower Max...
2019 JOHN DEERE R4023 LOT IDENTIFIER 243 (A53084)
2019 JOHN DEERE...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2017 Ford F-150...
Charlotte County (A50323)
Charlotte County...
Pintle Hitch (A51573)
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
