FEL boom is slow and leaks down after new control valve
   / FEL boom is slow and leaks down after new control valve #11
This valve block looks similar to yours. Ports are labeled. Power Beyond out of the loader valve should go to port #3.
   / FEL boom is slow and leaks down after new control valve #12
I am continuing to check the basics and would ask you review each of these pictures and make certain what you have installed on your valve matches the pictures for the float and power beyond and not the closed center.
Did the joystick come installed on your valve?
Could you post pictures of the box the valve came in and any other packaging with part # on it.
Could you post a picture of your invoice with your personal info hidden.
Dave M7040
   / FEL boom is slow and leaks down after new control valve #13
npalen
I re read the original and a later post making certain where his problem was. One thing he did say in his second post was that he had not changed anything on the valve block. This makes me think his issue(s) are in the new FEL valve and how it is connected and not the block. That is unless he has started making changes to the block now and things are totally confused.
How do you read his problem?
Dave M7040
   / FEL boom is slow and leaks down after new control valve #14
npalen
Dave M7040
Yes, I agree with you. Just thought the block diagram might be helpful.
   / FEL boom is slow and leaks down after new control valve #15
Thanks for your reply. I am never certain if I am misreading the problem as it is described.
Sometimes when I allow myself to focus on someone's technical problem, I invest a lot of emotional energy in finding a solution.
It is completely unreasonable but I wish the original poster was sitting at his computer ready to immediately answer any question i have. :)
Dave M7040
SCHAFFER 2430SLT LOT IDENTIFIER 137 (A53084)
SCHAFFER 2430SLT...
LOT IDENTIFIER 235 (A53084)
LOT IDENTIFIER 235...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2019 DODGE RAM 5500 SERVICE TRUCK (A51247)
2019 DODGE RAM...
MILWAUKEE 52" HIGH CAPACITY MOBILE WORKBENCH (A51248)
MILWAUKEE 52" HIGH...
(APPROX 12) 2" X 6" X 41" IRON TUBING (A51247)
(APPROX 12) 2" X...
