FEL boom is slow and leaks down after new control valve
   / FEL boom is slow and leaks down after new control valve #11
This valve block looks similar to yours. Ports are labeled. Power Beyond out of the loader valve should go to port #3.
   / FEL boom is slow and leaks down after new control valve #12
I am continuing to check the basics and would ask you review each of these pictures and make certain what you have installed on your valve matches the pictures for the float and power beyond and not the closed center.
Did the joystick come installed on your valve?
Could you post pictures of the box the valve came in and any other packaging with part # on it.
Could you post a picture of your invoice with your personal info hidden.
Dave M7040
   / FEL boom is slow and leaks down after new control valve #13
npalen
I re read the original and a later post making certain where his problem was. One thing he did say in his second post was that he had not changed anything on the valve block. This makes me think his issue(s) are in the new FEL valve and how it is connected and not the block. That is unless he has started making changes to the block now and things are totally confused.
How do you read his problem?
Dave M7040
   / FEL boom is slow and leaks down after new control valve #14
npalen
Dave M7040
Yes, I agree with you. Just thought the block diagram might be helpful.
   / FEL boom is slow and leaks down after new control valve #15
Thanks for your reply. I am never certain if I am misreading the problem as it is described.
Sometimes when I allow myself to focus on someone's technical problem, I invest a lot of emotional energy in finding a solution.
It is completely unreasonable but I wish the original poster was sitting at his computer ready to immediately answer any question i have. :)
Dave M7040
20ft Bi-Parting Wrought Iron Gate (A51573)
20ft Bi-Parting...
2023 CATERPILLAR 259D3 SKID STEER (A51246)
2023 CATERPILLAR...
UNUSED WOLVERINE BC-13-72W-72" HYD BRUSH CUTTER (A51248)
UNUSED WOLVERINE...
2007 Freightliner B2 School Bus (A51692)
2007 Freightliner...
New/Unused Agrotk Tire Changer (A51573)
New/Unused Agrotk...
2014 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A51246)
2014 CATERPILLAR...
