Stihl 4 mix vs Echo 2 stroke
   / Stihl 4 mix vs Echo 2 stroke #1
sawtooth
Eden NC
Ford NAA, Ford 2810, Ford 3910-1, Ford 3910-2, Ford 4600SU, Massey 2660 HD, Massey 461, Grasshopper 725D, Grasshopper 900D
Getting ready to buy a trimmer. Any thoughts on these two engine designs?
   / Stihl 4 mix vs Echo 2 stroke #2
When I bought my house 12 years ago I bought a Stihl trimmer, two chainsaws and a blower, The good news is they are all working fine 12 years later. I use only Stihl Motomix for my fuel.. Anything as far as these tools go, I will will stick with Stihl. Don't know anything Echo.
   / Stihl 4 mix vs Echo 2 stroke #3
I have the stihl 4 mix on my polesaw and backpack leaf blower. My string trimmer is an Echo 2 stroke. All 3 machines have been highly reliable. All are fed diet of Stihl ultra 2 stroke oil in 89 octane gasoline. If I needed a new trimmer, I'd just buy another Echo thinking it'd be a few bucks cheaper than a Stihl. (All my chain saws are Stihl, too.)
   / Stihl 4 mix vs Echo 2 stroke #4
Bought a Stihl 4Mix trimmer about 8 years ago. Would have to walk to the garage for model #..... it was the lowest cost model at the time that would fit a Stihl brush blade. Light use around home, occasional use on a remote property for heavy grass/weed clearing.
I've been happy with it. Doing it again, I'd spend a bit more for one or 2 models up in Stihl, that at the time had a bit better vibration isolation. For light use (less than 30 minutes), it's not really noticeable, and when I do longer runs I try and make sure I have decent cushioning in the gloves I wear. Engine has good torque.
Not sure where you are OP.... used to be around here Stihl would extend the factory warranty no charge if you bought a 6 pack of Stihl mix oil with the trimmer. Good oil, and a bonus extension to warranty.
Only negative I've heard with Stihl is with bigger recent motors - a bricklayer I know had problems with a concrete saw - I think it was the muffler mount design changed, and didn't stand up as well to vibration - can't see this being an issue on trimmers.
Like poster #2, I've no experience with Echo.
Rgds, D.
   / Stihl 4 mix vs Echo 2 stroke #5
I've never used a 4 stroke Stihl but I've used 4 stroke Troybuilt and Honda. I didn't like either one. As far as Echo vs Stihl I'd be inclined to go Echo as they're usually more bang for your buck. And why limit yourself to these brands? I own Shindaiwa, Red Max, Echo, and Husqvarna equipment and I've used my fair share of Stihl. All I'll say is you die hard Stihl guys are wearing blinders.
   / Stihl 4 mix vs Echo 2 stroke #6
Purchased a Stihl FS130 4 mix trimmer 2 years ago and have been very happy with it. Running a dual line head with .105 line it goes through large weeds and tall grass with ease. If I put a brush cutter blade on it will handle saplings in the 2" to 3" size. Just incredible amount of power this trimmer has.
   / Stihl 4 mix vs Echo 2 stroke #7
It's amazing what you can cut when you ditch the more common 4 sided blades and get something with some teeth on it. Btw you're cutting those saplings with mostly momentum instead of engine power.
   / Stihl 4 mix vs Echo 2 stroke #8
I'd get the Echo -- they make a great trimmer.
   / Stihl 4 mix vs Echo 2 stroke #9
Never used either of those blades. Never even considered the 4 sided one. Just didn't seem like it would work to me. I use string or a tooth blade.
Always wondered if those chain saw blades were any good.
TBS
   / Stihl 4 mix vs Echo 2 stroke #10
TBS
I have one although a different brand. It worked great but didn't stay sharp very long. The dull blade still cuts briars and 1/2" brush pretty well, but it doesn't do to good on big stuff anymore.
2009 Haybuster GP-50 Grain Processer (A55315)
2009 Haybuster...
2020 CATERPILLAR 299D3 SKID STEER (A60429)
2020 CATERPILLAR...
*Selling at Royal Auction Tampa, FL Location* (A59231)
*Selling at Royal...
Forestry Truck Grapple and Frame (A55851)
Forestry Truck...
2012 International 4300 Reefer Truck (A56438)
2012 International...
2024 Frontier FL1061S Hydraulic Flail Mower (A56438)
2024 Frontier...
