LED lights and radio question?
   / LED lights and radio question? #11
Wrapping the power cord in a good sized toroidal ferrite might be productive. I would want to start with one you could get at least a half dozen wraps thru. As for the snap on ferrites, If you had enough of them it might work.
   / LED lights and radio question? #12
Static from these is not limited to the AM band ...
   / LED lights and radio question? #13
   / LED lights and radio question? #14
I guess the same go's for fluorescent lights, I have the same situation in my shop.
My interference problem went away after swapping out my fluorescents with Costco 4ft LEDs in my shop. No more buzzing and slow start up anymore either.
   / LED lights and radio question? #15
True, from what I have heard, some of them have emissions on up into VHF frequencies.
It is amazing how noisy everything has become, with the swing to digital TV and FM broadcasting. Still carries the sticker of compliance of course.. but noisy as heck. Cordless phones were a major headache once but now they are higher in frequency it helps them beat RFI. I can recall the days of our Monday night net on 75M most of the locals knew when we were on the air. Bars across the TV and a racket on the phone..
It's an FM station that I usually listen too. Would running another power line to the shop that is separate from the other power line help with this situation? Or, does the led cause the problem through the air to the antenna or something? I am very happy with the new lights but sort of bummed out about the radio situation. Would a better radio work around this? If i moved the radio outside, will it stop this? Just wondering and guessing. :confused3:
   / LED lights and radio question? #17
An outside antenna for the FM radio would likely help. The more seperation between the lights and the antenna the better. The radiation if likely from the lights into the power line and radiation along the power line and thru the air from the power line both.
However, the FM frequencies would lend itself much easier to using some snap on ferrites on the line to help prevent this radiation.
Describe your lights and what feeds them.
Amazon.com: snap on ferrite beads
   / LED lights and radio question? #18
James these go on the power to the radio or lights? With your link :thumbsup: it looks like a simple and pretty cheap fix. One of the responses here was to throw out the lamp and get another, my luck I'd have a pile of "anothers" before I fixed the problem.:laughing:
   / LED lights and radio question? #19
The 8' fluorescent lights, in my shop, are about 16' above the floor and hung on chains from ceiling so, replacing the 8' T12 tubes is a major PIA. I bought one of these online from Home Depot for a trial.
EnviroLite 8 ft. 4-Light White Industrial LED White Strip Light with T8 LED 5K Tubes-ST74T185 - The Home Depot
It works great and very bright. No interference to either AM or FM on shop radio either. I'm going to order 8 more for complete replacement of my overhead lights. If I do have to replace one of the LED tubes, in the future, it will still be easier than replacing the 8' tubes. With the fixtures being hung on chains you have to hold fixture with one hand and stab tube with the other, on a 14' step ladder.
I also bought one each of the 4' LED lights from Sam's Club and Costco for trial to install above specific work areas in my shop. Neither cause any radio interference. I prefer the light from Sam's as the LED tubes have frosted covers which, I believe, disperses the light better.
   / LED lights and radio question? #20
They go on the power leads to the lights as close as possible.
2016 FORD F-150XL SINGLE CAB TRUCK (A51406)
2016 FORD F-150XL...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
2000 JOHN DEERE 444H WHEEL LOADER (A52705)
2000 JOHN DEERE...
2019 GENERAC MLT6SK-HERC LIGHT PLANT / GENERATOR (A52706)
2019 GENERAC...
2023 CATERPILLAR 299D3 XE SKID STEER (A52705)
2023 CATERPILLAR...
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A55218)
Galvanized...
