"Flex Fuel" Tundras and 5,000 mile OEM oil change interval?
   / "Flex Fuel" Tundras and 5,000 mile OEM oil change interval? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
I have a 2011 Toyota Tundra V8 that is a so-called Flex Fuel vehicle in that it can run on E85, something I would never do. In fact, I would run exclusively on E0 if it were more widely available. The OEM on these Tundras mandates a 5,000 mile oil change with a flex fuel engine. Period. End of discussion. By the way, I run Mobil1 5W30 and tow 1/4 of the time.
Come on, this doesn't make sense. I know the oil has lots of life in it so what's so special about a flex fuel vehicle that means change the oil at 5,000 miles in a 7,500 or 10,000 world? Do we go to He** for failure to comply? Find our beds short sheeted at night? Maybe the engine takes a powder and throws a rod through the pan?
None of that seems likely so does anyone know?
**Come to think of it, my 2015 Tacoma 4 cylinder regular fuel engine also mandates 5,000 mile oil change. Surely, I'm the only one out of the loop here and I don't get it.
   / "Flex Fuel" Tundras and 5,000 mile OEM oil change interval? #2
My 2011 Ram 1500 with the Hemi calls for 8000 mile oil changes, but I try to change the oil everything 5000 or so. Heck if I listened to the dealer and pay attention to their oil change sticker on the windshield they would have me changing it every 3000 miles.
   / "Flex Fuel" Tundras and 5,000 mile OEM oil change interval? #3
Seems to me 5,000 mile oil changes makes nice round numbers to help remember when to do it.
   / "Flex Fuel" Tundras and 5,000 mile OEM oil change interval? #4
Most vehicles now come with a oil change computer that tells you when to change based on engine RPM, engine temps and other use related items. Every new car I have bought since 2003 has these and my dealers always tell me to just change it when the computer tells you to OR once a year. The computers are based on using regular oil so if you use a synthetic, you could go further.
I base all my oil changes off the computer since I have the old age syndrome of CRS anymore. I do write the date of change on any filter that can be seen without removal. I have one car that is impossible to see the filter, well maybe if I jacked it up, scooted under it and looked up thru the frame hole that allows you to reach the filter. Then with the help of a strong flashlight I might be able to see the bottom of the filter, but why work so hard at it when the computer tells me when I need to change
   / "Flex Fuel" Tundras and 5,000 mile OEM oil change interval? #5
Wouldn't doubt it has something to do with Toyota getting sued for oil sludge engine failures in the nineties and early 20's
Kind of a side thing here, I keep a notebook with all info regarding oil change, any filter change, tire rotation and other info like part numbers or tire pressures or oil/trans capacities. Come showtime, I'm good to go in a moment's with whatever I need for info. Saves money, time and memory.
   / "Flex Fuel" Tundras and 5,000 mile OEM oil change interval? #7
I'm a Mobil 1 guy myself. I'll spin a new filter on between 3 to 3.5k and a complete change out @ 9k. Been doing it this way for close to 30 years now.
   / "Flex Fuel" Tundras and 5,000 mile OEM oil change interval? #8
Just bought a new Land Cruiser (5.7) , calls for oil change every 10k miles! I changed brake in oil at 1500, and plan on every 5k. Takes that new 0/20 oil, that scares me in Texas heat.
   / "Flex Fuel" Tundras and 5,000 mile OEM oil change interval? #9
I can think of 2 reasons. First, Toyoda being conservative in their spec, possibly partly in response to sludge problems in certain motors. You use a quality oil 6d, but not everybody does. Toyota may want to over-spec the oil interval (therefore, just about any oil will do), rather than have to argue with customers about out oil quality.
The other issue is the alcohol itself. Don't know if your motor is DI, but regardless, fuel dilution can be a concern with E85. OLM computers should be programmed to deal with such things, but let's say a truck spends all Winter in northern Canada doing short-trip cold-starts - it will spend most of the time running relatively rich at that temperature. In an extreme case like that, I can see why they'd want the oil changed sooner with E85.
Rgds, D.
   / "Flex Fuel" Tundras and 5,000 mile OEM oil change interval? #10
My F150 5.0 is flex fuel. They list no difference in oil change frequency regardless of fuel, but do say to run a tank of Unleaded gas through it at every oil change (if running E85 exclusively). Change intervals for extreme use (dusty sandy, etc) is 5k miles, otherwise 10k I believe.
I ran 2 tanks of e85 in the early fall, back to back, to act as a system cleansing.
   / "Flex Fuel" Tundras and 5,000 mile OEM oil change interval? #11
I had an '07, 5.7 Tundra and changed the oil/filter every 7500 using Mobil 1, 0W30. It had 130,000 on it when I traded this past December and would go the 7500 miles and be down about an eighth of an inch on the stick. The '16 1794, 5.7 Tundra has a 10,000 mile oil change interval. We have nothing but 10% ethanol blend available to us here in the northeast. So long as you use nothing but 10%, I see no reason you can't go 7500 between oil changes; there is nothing special about a flex-fuel engine that would prevent you from doing so.
Rgds, D.
My oil change interval is at 5,000 miles on E90. On E85, it's only 2,500. And they mandate synthetic oil. No sludge there.
Patches--Is yours a FFV? That's what I don't get. The same truck, one a FFV and the other not and two separate oil change intervals even though usage is exactly the same.
   / "Flex Fuel" Tundras and 5,000 mile OEM oil change interval? #14
Negative, no FFV
   / "Flex Fuel" Tundras and 5,000 mile OEM oil change interval? #15
E90 - did you mean E10 ?
Yoda sludge issues I know about are in 4 bangers, wasn't alluding to a specific problem in your 8 - just that they may have done an across the board dial-back of intervals.
Is your motor direct or port-injected ?
Rgds, D.
Oops; yes...E10. Duh on my part.
Have no idea on direct or port but can look it up.
   / "Flex Fuel" Tundras and 5,000 mile OEM oil change interval? #17
OK, then I follow Yoda's logic.
IF there is any fuel dilution of the oil going on, then you want the oil changed earlier when running E85 - metallic bearings that I'm familiar with won't survive long using ethanol for lube.
Rgds, D.
   / "Flex Fuel" Tundras and 5,000 mile OEM oil change interval? #18
I also have an F-150 flex-fuel 5.4L. Back when I could get E-85 I liked to run a tank of it thru shortly before my next oil change. I run ethanol free when I can (most of the time) but I know that E-85 would pull accumulated condensation thru and burn it on out. Something I'd like to remove with the subsequent oil & filter change. I do everything on 5000 mile intervals because its easy to remember.
   / "Flex Fuel" Tundras and 5,000 mile OEM oil change interval? #19
Toyota says 5,000 so do it at 5,000. Oil is cheap, engines are not.
   / "Flex Fuel" Tundras and 5,000 mile OEM oil change interval? #20
The 5.7 Toyota is port injected
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Dodge Charger (A56859)
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
DOOSAN G25KW GENERATOR (A55745)
DOOSAN G25KW...
UNKNOWN 500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
KUBOTA L3901D TRACTOR (A59823)
KUBOTA L3901D...
