Truck Oil change intervals
   / Truck Oil change intervals #21
The "service light" on my truck senses nothing. It's merely a built in trip meter. Nothing exotic. The Fords we're driving use a "percentage remaining" read out. Whatever that is. Don't know, and don't particularly care. Everything on the property gets serviced regularly on schedule. I sleep really good at night.
   / Truck Oil change intervals #22
The service light runs off combustion events. I have run Mobil 1 since it came out. Fram also sells a 15K synthetic oil filter and that is what I use.
If you are in the warranty zone remember that the dealer can read when you have reset the light. Also and more important Save your receipts for your oil and filter purchases with documentation of when they were used on the truck. If for some reason something goes wrong the dealer may well not repair the thing under warranty if you can't prove the oil changes. I have seen this more than once at the dealer where I worked. Why a lot of people suggest you let the dealer do it till the warranty is up.
So to be safe I would change it when the light calls for it to be changed and keep your receipts till you are out of warranty then no problem on the 15K oil and filter changes.
Just a note, The GM dealer uses Mobil oil and on the cars that they put Mobil 1 and the conventional oil in they use the AC Delco filters.
Ultra Synthetic Oil Filter | FRAM
I wouldn't use a FRAM filter unless it was the only thing available.
   / Truck Oil change intervals #24
Well that is just YHO. I have seen many filters and the construction of the Fram Synthetic filter is top quality. If you open up a AC Delco filter you will find paper at the end plates. Not metal like the Fram. You buy the cheapest filter on the shelf and you get what you paid for. And that is JMHO.
You asked for input in the first post and now you are the expert???????????????? :mur:
   / Truck Oil change intervals #25
The only real way to know if you NEED to change the oil, is to do a Used Oil Analysis. I use Blackstone Labs to do my UOA. I routinely put 12-14,000 miles on an oil change with my 7.3 diesel. The recommended interval is 5,000 miles. BUT that is with MY driving. In all but one oil change, I was throwing away perfectly good oil even with the high mileage. One time I had diesel fuel in the oil, still within parameters, due to getting stuck in traffic. Thankfully, I was able to stop driving in that traffic and no more fuel in the oil.
Either change by the book, and most people are likely to be running severe service, or get the UOA and change per the results. Anything else is a guess. Well, changing per the book is a guess but a good, SAFE one. :laughing::laughing::laughing:
Later,
Dan
   / Truck Oil change intervals #26
My experience is with an '04 Sierra 5.3l. Used Mobil 1 since it's first change, usually with a Mobil 1 filter, but sometimes a Bosch or Delco, anything that I consider to be a good-quality filter (never Fram), and changes whenever the "oil monitor" says. 280,000 mi so far, still uses almost no oil between changes that are usually about 8-10k, sometimes more. Have done NOTHING to the engine except oil/filter changes, air filter changes, one rebuilt alternator, and 2 sets of plugs (one new set of MSD wires).
Not an expert, I just know FRAM filters are the bottom of the barrel when it comes to air and oil filters.
   / Truck Oil change intervals #28
I would tend to agree with that on the regular Fram filters. But if you look at the link on the Synthetic Fram filter it's construction is much better and comparable to others. I only stated I use the Synthetic filters.
Here is some interesting reading. Keep in mind this comparison is the premium filters for Mobil 1 and Bosch and the Fram is their bottom of the line filter. So not really apples to apples.
Oil filter comparison, 4 top brand oil filters cut up and compared. - NASIOC
   / Truck Oil change intervals #29
I hear this all the time and unfortunately you are mis-informed.
The fram XG and even the TG filters are top of the line and rate right up there with the best of the best in several independent tests.
Sure, there low end filter isn't up there on quality and I wouldnt use a standard fram PH series. As with many other things, one company (fram) makes many different levels of quality. You get what you pay for. A $3 filter is just that. Their TG and XG filters are ~$10, and compare well with all the other higher end filters out there.
So do your homework and stop bashing fram all-together and just repeating what is said so many times on the net about fram making a crappy filter.
   / Truck Oil change intervals #30
The change oil message on the dash of my 2012 colorado says that it uses computer calculations based on speed, engine rpms and temperature to adjust oil change times. I guess i pretty much drive the same type and idle the same amount all year so even in the short term it does not matter if i idled more...or drove more interstate miles. But anyway it sure seems to go off at 9,600-9,800 miles every time!! And i have read others on the internet that says thiers go off on the same truck pretty much the exact same time as mine so i would argue as well its just an oil change odometer. But maybe its set to the 9800 mark but if your really do a lot of towing or literally sit around at idle for half a day maybe it defaults to like 5k? But unless mark A,B,C and or two of them are met it will not shorten the change life?
   / Truck Oil change intervals #31
wheres our like button!
   / Truck Oil change intervals #32
Thank you I agree. :thumbsup:
On another note, even the worst and crappy filters sold meet or exceed OEM specs. So what does that say about that OEM AC Delco. Ford, Dodge or the other manufactures filter????
My 2011 Silverado with 5.3 runs to about 7,600 to 8,100 before it calls for a oil change. Most of my driving is around town. My wife who does highway driving gets 10,000 to 11,000 before the light comes on. Makes sense for the combustion events trigger.
I'll bash what ever in the **** I want to. Orange filters are like orange tractors. Oops sorry!! Just kiddin, lighten up Francis
   / Truck Oil change intervals #34
Yep, bash whatever you want. I'll treat you as such......an un-informed poster that just repeats what he hears someone else say. Personally, I'll do my research and form my own opinion rather than be a follower and try to spread bad information.
   / Truck Oil change intervals #35
I like using NAPA gold oil filters. Anything wrong with them???? I have never had a oil filter fail on me out of all the different brands I've used but I always changed oil when I was supposed to.
   / Truck Oil change intervals #36
Not in my book. They are what I use on my truck, fuel filters for the BH, trans filter for the backhoe. Same as a wix
Fram is kinda like buying a Dodge Truck, it looks good on the outside.
   / Truck Oil change intervals #38
More ignorant comments/posts instead of doing some research and learning the facts
I knew that would get you going. I'm just yanking your chain.
   / Truck Oil change intervals #40
Is that your sole purpose? To spread bad info and get people all fired up? Pretty lame. I'm on here for different reasons.
GIYI SGB20-20" HYD STUMP GRAB BUCKET (A60430)
GIYI SGB20-20" HYD...
EXCAVATOR JACKHAMMER (A58214)
EXCAVATOR...
UNUSED RAYTREE RMLS18T-18 TON HYD LOG SPLITTER (A60432)
UNUSED RAYTREE...
2012 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A59904)
2012 FREIGHTLINER...
(2) NOS-8 LUG- 7000Ib 74SC-93 HUB FACE DROP AXLES (A60432)
(2) NOS-8 LUG-...
2017 Subaru Impreza AWD Hatchback (A59231)
2017 Subaru...
