Do you know who makes this?
   / Do you know who makes this?
Thanks. A good read. I will dig into the mower a little deeper when I get off later this week. Working night shift right now and getting too old for this stuff. Bad to the bone when I was 25....now just old broken down bones at 61 (soon to be). I needed to find out what I have before digging into the gearbox.
I would drain the oil out of the gearbox and replace it with corn head grease. It will provide lubrication in use but won't leak out.
If it works, you can't lose for only $250. Congrats.
Is that the JD stuff that is highly touted?
Did that with my flail I paid $100 for. New seals for the gearbox were going to be almost as much as I paid for the mower.
Grease won't be quite as good as oil, but realistically the gearbox running any lube is gonna outlast the rest of a used mower unless the bearing are already shot.
Haha, your luck was even better for $100.
On the link http://www.tractorbynet.com/forums/attachments/358766-big-bee-agri-five-rotary.html
In the first pic, the long bar that goes from the 3 point upright to the back, just in front of the tail wheel housing, is just attached by a chain at the rear. Is this supposed to be more like a free floating 3 point attachment?
On my old 4' cutter, it is a rigid mount and I used limiter chains to keep the height, when going over rougher ground.
   / Do you know who makes this? #17
I found this thread and it is identical. For some reason I cannot copy that photo to paste in here. ------------------
Here it is, it belongs to Joe13:
Yes most brush hogs have linkage or a chain that allows the back to be able to raise up without forcing the 3 point lift arms to move up.
   / Do you know who makes this? #18
Looks almost exactly like one I bought at Tractor Supply around 1992.
I found an old picture of my box blade, which was the same brand as my brush cutter. It was Huskee brand from TSC.
   / Do you know who makes this? #19
There needs to be some slack in that top link flatbar. I'm guessing he was getting that slack by fastening it with a chain at the back. It's not always had that luxury. that's obvious by the places on that flatbar where the paint is gone. This is where it has bent previously cracking the paint.
I'm also a bit concerned about the height of the 3pt pins? Are you sure your tractor will lift it high enough. Looks like it's been cut and changed at some time. Maybe elevated so a "taller" tractor could use it??
I wouldn't do anything with the gearbox until I had it useable in regards to the hitch and top link.
Unless you plan to use this cutter extensively, I'd not worry about replacing the gearbox seal. I'd do just what he did and pump it full of grease.
Keep us posted on your progress!!!!
   / Do you know who makes this? #20
I bet you could remove the lift pins & move the into the lower holes at the bottom where it attaches to the deck.
I wouldn't worry about the chain at all & leave it be. Make sure it fits & you can lift it, pump the gearbox part way full (don't want to fill it full for the usual expansion reasons) of grease then let er rip.
SAKAI SV510 SMOOTH DRUM ROLLER (A51242)
SAKAI SV510 SMOOTH...
2011 INTERNATIONAL PROSTAR +122 6X4 DAYCAB ROAD TR (A51243)
2011 INTERNATIONAL...
2011 BMW X5 SUV (A50324)
2011 BMW X5 SUV...
2 Vintage Metal Signs (A48081)
2 Vintage Metal...
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
2015 PETERBILT 579 SLEEPER (A51222)
2015 PETERBILT 579...
