Finding point of failure - diverter valve or FEL control valve
   / Finding point of failure - diverter valve or FEL control valve #61
ljplum,
Did you get a chance to check the spools including that back spring?
   / Finding point of failure - diverter valve or FEL control valve #62
ljplum,
Forgot to mention-
When you begin to work on the spools, be sure that the FEL is at rest (engine off, wiggle the FEL controls to release any pressure)
I got the spool apart and checked, and everything seems fine Everything was held together and there was no debris or anything. I'm having issues getting it back together though. There are two ball bearings that fit inside a sleeve. I can't get the bearings in far enough to get the sleeve over them.
   / Finding point of failure - diverter valve or FEL control valve #64
Did you happen to take a picture of the entire spool right after you removed it? Which end of the spool are we looking at?
I got it back, I just wasn't using enough oomph.
I'm back after a few weeks of down time.
I put everything back together and still see the same results. From what I've learned this means it's likely the cylinders so I went ahead and pulled one of the lift cylinders off.
Does anyone have any advice for removing the gland nut? It's made of aluminum and strips pretty easy.
   / Finding point of failure - diverter valve or FEL control valve #67
When I rebuilt my cylinder I found the best way was to leave it on the tractor until the gland nut was loose, use the mounting bolt to hold it while you crack the nut. I used a large plumber's crescent wrench.
Had a buddy help me get it off. Destroyed the gland nut in the process, but this is what he found. I still haven't seen it in person, just the picture. It looks like the piston seals are completely gone. As in not there.
   / Finding point of failure - diverter valve or FEL control valve #70
That's odd. Were they damaged and your buddy just took the seals off for the picture?
I have never seen a cylinder completely missing the seals. If a seal started to deteriorate and come apart in chunks, I would have thought you would have had issues long before the seal was completely gone. Plugging up small passages in the valve and quick couplers. So gotta wonder where all that seal material is now floating around in the hydraulics, or if the filter caught it?
   / Finding point of failure - diverter valve or FEL control valve #71
I had a LW-6 Chinese backhoe that I tried using synthetic hydraulic oil in. The oil actually turned black and literally dissolved the seals, but not totally. There was still some black goo around the pistons, and the nylon wiper rings were still there.
I've done a flush and changed the filter, so hopefully if there was any debris it's gone now.
I've got another update and another issue. The second piston was about as bad as the first, the seals were completely gone. Someone on here's advice helped a lot in removing the gland nut, and this time I used a pipe wrench but didn't remove the cylinder first. It came off much easier. I went ahead and ordered all new pistons and glands with the seals all installed. That unfortunately cost me $100/cylinder instead of $40/cylinder, but I didn't have to worry about messing up the seals trying to put them in.
When I got it all back together, I still have no lift. Bucket curl works. Since I have faith that it's not the cylinders at this point, so I swapped the line for lift and bucket curl on the spool valve. With the lines swapped, the lift works, and the curl doesn't. So, it's gotta be the spool! I took it apart again to see if I could determine the issue, and everything looks fine to my untrained eye. My question is, if I'm looking for the failure mechanism in a spool valve, what am I looking for? As far as I can tell there are no seals or o-rings in the spool itself that could go bad. I checked all the various plugs and ports to see if anything was clogged and see nothing.
   / Finding point of failure - diverter valve or FEL control valve #74
Pull the spool from the section that works. Compare both very close.
MAYBE somebody played around before you and put things together backwards.
   / Finding point of failure - diverter valve or FEL control valve #75
Just a thought have you called Koyker Mfg. and talked to them? When I had problems with my loader and though it was the spool valve I called them talked to their parts and service people they told me what the problem was and sent me the parts I needed. Their number is 1 800 456 1107 give them a call.
I've called and e-mailed Koyker a few times now and haven't gotten through or gotten responses from their actual service department.
It's possible I put things back together incorrectly. This spool has a float position on it and the second one doesn't, so I can't really compare directly. I have the mechanical drawing for the valve, and based on it I think everything is right. If it's not right, I can't tell just by looking at it.
   / Finding point of failure - diverter valve or FEL control valve #77
Did you solve the problem?
Now we know that the spools can't be switched. But I thought maybe somebody turned parts around and put left to right, front to back.
UNUSED RAYTREE RMA42 HYD AUGER (A60432)
UNUSED RAYTREE...
2002 TOYOTA 7FDKU40 FORKLIFT (A57880)
2002 TOYOTA...
Pace American MW8516TA2 T/A Enclosed Concession Trailer (A56857)
Pace American...
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
THREE POINT ATTACHMENT (A58214)
THREE POINT...
2018 Kia Soul SUV (A59231)
2018 Kia Soul SUV...
