cutting holes in steel gate post for hinge bolts
   / cutting holes in steel gate post for hinge bolts #71
Careful some fellers won't weld anything less than 1/4" for that same reason. :laughing: :laughing: :laughing: When you think like a hammer all you see is nails. I can see how that would happen when you buy a refined unit like that mag drill! How would you STOP drilling holes in everything?
Can you bear to etch that shiny metal before painting?
   / cutting holes in steel gate post for hinge bolts #72
I don't stop drilling, I just GRIN a lot more :D Then I come up with ways of drilling EVEN MORE HOLES without having to actually stop and MEASURE where they go - This "V2.0" version uses a couple inexpensive DP vises on a Grizzly XY table - both axes of the table use 10 TPI lead screws, so (in this example) I wanted 13 1/2" holes on 1" centers, both sides of 2.53" receiver tube and aligned for adjustment pins, with a 1" acme "fine adjust" on C-channel feet -
Each set of 26 holes took me about 10 MINUTES TOTAL thru 1/4" wall tubing. 10-12 seconds per hole, then 10 turns on the table crank and repeat. Only measurement required was to scribe a line around one end where the holes would start, then start there when doing the other side and keep count of the crank turns. all hole pairs line up so a 1/2" bolt or pin can go all the way through. Those 3 "feet" will be part of a steel-framed fiberglass roof that covers my 20' container and a 14'x24' covered work area. The non-container area will get a slab poured so I can work on my hoe/tractors/implements out of whatever weather is irritating me at the time :thumbdown:
Last 2 pics are showing the modular roof framing so I can manage smaller sections alone with lift gear and the hoe - it can also be dis-assembled in modules and moved if necessary, which is the reason for so much adjustability in the outer legs - when in place, the roof will have a continuous 2/12 slope with enough headroom on the slab to drive anything thru that has less than 12 foot overall height - it'll also have steel-framed fiberglass sliding doors all around to help with the sometimes 40+ MPH winds on our hill... Steve
   / cutting holes in steel gate post for hinge bolts #74
   / cutting holes in steel gate post for hinge bolts #75
Big, here's the same sizes you're looking at, and same brand Sodo linked for a couple bucks less, with TWICE the depth of cut
Blair 119 Rotobroach Cutter Kit Hole Saw Kit - Hole Saw Sets - Amazon.com
- dunno if you intend any holes thru thicker than 1/4", but if you do..... Steve
Oh, and in case you forgot lube (bad idea)
Hougen Slick-Stik Mini 1.68oz Lube Tube - Power Tool Lubricants - Amazon.com
or
Amazon.com: Blair 1175 Lubricant: Automotive
Thanks bucket. I updated the order for the deeper set. The original order was for 2 tubs of grease. I'm curious to what kind of grease it is.
   / cutting holes in steel gate post for hinge bolts #76
You're welcome - I just know how irritated I get with myself if I miss some detail like that and end up kicking myself every time I use it instead of ENJOYING the new tool like it SHOULD be :confused:
I ordered the same set you did, the actual mag drill cutters STOP at 7/16" on the small sizes, I'm hoping this kit works close enough to the bigger ones to make me glad I bought it. I ordered the Hougen "slik stik" lube, it's kind of a waxy paste from what I read. Hougen makes it VERY plain in their docs that DRY drilling will cost you a LOT; apparently lubed the cutters last several TIMES as long as dry. So far all the drilling I've done has been vertical, so I use the 10:1 lube in the built-in coolant system -
Carbide ones might do better un-lubed, but even the HSS ones for mag drills run anywhere from $30 to $150 EACH, especially in the 2" DOC cutters I buy - carbide runs real close to TWICE what the HSS ones do, kinda adds up (or multiplies, more like :confused: ) - I'd have somewhat over $1k in cutters if I'd bought these in Carbide - 'specially since there's another kit of 5 cutters (not in that pic) that was part of the package I bought... Steve
   / cutting holes in steel gate post for hinge bolts #77
That advice comes a little late for me. I used the lock button and that's why I had to splice my cord :)
Mine likes to wait till you forget about it's hidden feature of shocking the **** out of you at random times!
   / cutting holes in steel gate post for hinge bolts #78
It is just trying to "light up" your life! :laughing:
2017 Dodge Charger Sedan (A55853)
2017 Dodge Charger...
2019 Chevrolet Silverado1500 LD Crew Cab Pickup Truck (A55852)
2019 Chevrolet...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
2001 CATERPILLAR 420D BACKHOE (A52707)
2001 CATERPILLAR...
2025 Spirit Electric Scooter (A55853)
2025 Spirit...
Metal Peacock Lawn Art (A55853)
Metal Peacock Lawn...
