Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #4,451
Thanks BK, I guess that driveshaft joint let go on the stuck white truck? Ya got "big stuff" around to yank it out?
   / Tractors and wood! Show your pics #4,452
No the drive shaft was before that. We moved to a new block with very soft ground. I came into one spot in low at 2000 rpm and it sucked my 600 horses down to 1100 rpm. Poor Peterbilt was torqued so bad the passenger side of the steering axle was thumping the stopper and the drivers side was barely leaving a track. The rest of the 7 km was in first and second gear. We were putting on 840 KMs a day and two days later I started vibrating when I got in the hills on the highway, at the next roadside pullout I pulled in and didn't even need to crawl underneath to spot the bad one. Just took it out and finished my day on the front two axles. The picture where I'm stuck is the dang mill yard they wanted to try pulling it but I made them unload it there and after I just slapped the lockers and backed out.
   / Tractors and wood! Show your pics #4,453
Looks like money making load. :)
   / Tractors and wood! Show your pics #4,454
Not too bad. Better when winter weights are on like right now. I drop that pain in the *** lift axle. Summer weight with it on I'm legal at 63400kg, winter with it off I'm legal at 65000kg.
This is the real money maker though. This one is legal for 71300kg summer and 79300kg winter. The king-B is even better, they have the tridem pup. They are up in the 80000kg ranges.
   / Tractors and wood! Show your pics #4,455
Nice photo ! I love those big loads you guys have out there. Biggest loads I see around here aren't even close to that.
gg
   / Tractors and wood! Show your pics #4,456
What would be the horse power of diesel motor?
   / Tractors and wood! Show your pics #4,457
Yeah things sure have changed around here in the last 10-15 years.
   / Tractors and wood! Show your pics #4,459
IMG_20160828_174534376.jpgThe little tractor that could. I removed these stumps with the loader.
2008 JLG 1930ES ELECTRIC SCISSOR LIFT (A52705)
2008 JLG 1930ES...
UNUSED IRANCH IRGC40 HIGH END MINI GOLFCART (A54757)
UNUSED IRANCH...
2008 KOMATSU PC200LC-8 EXCAVATOR (A52706)
2008 KOMATSU...
2016 Ford Focus Sedan (A53424)
2016 Ford Focus...
UNUSED LANDHONOR 5/16" 7' G80 DBL CHAIN SLINGS (A54757)
UNUSED LANDHONOR...
UNUSED WOLVERINE SP-15-84W SNOW PUSHER (A54757)
UNUSED WOLVERINE...
