Price Check Buying a BH92 with Hydraulic Thumb NH
   / Buying a BH92 with Hydraulic Thumb NH #11
Also, $12k will buy a serviceable full size backhoe. Something else to think about... :drink:
If you shop, you may be able to get a second heavier stronger tractor for near the price of the BH 92, so, yup I'd think about it if you have room and can fix stuff.
   / Buying a BH92 with Hydraulic Thumb NH #12
Welcome to tbn. Love my bh92. I don't have a thumb, for that amount of money I'd get a grapple instead, or a manual thumb.
   / Buying a BH92 with Hydraulic Thumb NH #13
You should be able to take your tractor there and have them assemble and install the backhoe for that price. Also the manual thumb should be around the neighborhood of $750, and it meshes really well with the bucket teeth. In the thread linked above I mention about converting my manual thumb to hydraulic, copying what some others on this site have down. It's basically an electric over hydraulic setup, teeing into the bucket lines and using a normally closed solenoid valve on the cylinder side port of the thumb cylinder. I did have to remove some metal from the thumb to clear the fittings on the rod side port, and it's a longer cylinder than OEM so the thumb doesn't sit as tight against the dipperstick, but you should be able to do the entire conversion for less than $500, and the OEM thumb cylinder costs over $600.
Thanks for your response!
You mentioned the mechanical thumb... Can the mechanical thumb be converted to hydraulic using all of Kubota's parts? In other words.. Could I buy the cylinder and valve kit later and mount everything that way? Or, does the mechanical thumb differ from the hydraulic thumb?
Tough choices when you're about to lay out a lot of money!
   / Buying a BH92 with Hydraulic Thumb NH #15
The thumb itself is the exact same thing. I've looked at the part numbers of both and it's the same part number. I would imagine though that it's going to be more expensive to buy the parts separately than to buy them as a kit when you get the backhoe.
Still shopping around
Went to a dealer who had two BH92s on the lot in crates. He quoted me $7700 with an 18" bucket before tax translates to $8162. Only problem with this is I'd have to move it 7 hours north.
I think that is a pretty good price! As mentioned before, I have the frame and hydraulics on my tractor already.
   / Buying a BH92 with Hydraulic Thumb NH #17
You have a "saved search" on CL for each of the New England states?
Pulled the trigger yesterday on a BH92. Picking it up in a few days in a crate and putting it together myself. I think it'll be a fun project!
I did not go with any thumb at this point, too much added cost up front.
I hope to make a pretty extensive youtube video documenting the whole thing.
   / Buying a BH92 with Hydraulic Thumb NH #19
Congrats!
   / Buying a BH92 with Hydraulic Thumb NH #20
Greenworks Commercial 82V Utility Vehicle 500 CAMO Model: U500SC - DEMO UNIT (A56436)
Greenworks...
Bush Hog 3pt 14' Mower (A53317)
Bush Hog 3pt 14'...
2012 AMERITRAIL (A55745)
2012 AMERITRAIL...
2008 KOMATSU D51PX-22 CRAWLER DOZER (A60429)
2008 KOMATSU...
2017 Ford Transit 250 Cargo Van (A59230)
2017 Ford Transit...
2014 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
