Tig Welding Failure, what am I doing wrong
   / Tig Welding Failure, what am I doing wrong #11
Since you are trying to weld thin steel,,, and you have some copper laying around,
why not try putting the copper under the steel as a heat sink.
Although a lot larger, this was the same problem.
I wanted to abrasion resistant weld the edge of some tiller tines.
I clamped some copper under the tiller tine, and stick welded (1/8" rod)
I would avoid trying to weld copper until you master welding steel.
Copper can be VERY tricky to weld, especially if you do not have the machine completely figured out.
   / Tig Welding Failure, what am I doing wrong #12
As a beginner, You may want to drop back to 1/16 tungsten. Mainly for the thinner stuff. without pulse or Hz adjustment you will see a little less trouble with the smaller tungsten. Then practice..
   / Tig Welding Failure, what am I doing wrong #13
Yup, I hung up my scratch tig kit today. I reversed the Polarity, and while it spread out the heat, once the copper got hot it still just vaporized no matter how I moved. It is clear to me that the 20 amps my meter reads on my welder is more like 50.... There is probably some way to check this...
Anyway, I did tig on thicker metal, and it works pretty sweet. Slow as snot but I get it and I get how cool it could be.
The downside is that I am 100 in the hole on a scratch start tig system I will not use. The upside is that I see a nice tig rig in my future.... Tigging is pretty cool, I don't want to say easy but I get how it is an attractive way to weld.
If you have a DC tong meter or borrow one, You can clamp in on your ground and it will tell you true amp output.
   / Tig Welding Failure, what am I doing wrong #14
Well, been doing a bit of reading. Going to try reverse polarity today. see how that works.
But in the end I think it is my wonderful and very powerful Everlast 200. I always felt that bad boy was hot, but with Shields comments I am now confirming that that little box is a great stick welder.
Reversing the polarity results on melting the tungsten like it is a stick rod. If you reversed polarity and it didn't melt the tungsten, then you may have some polarity problems with your machine. I think your machine is running much more amps than indicated, 20 amps should allow you to weld any sheetmetal without burning thru. I wouldn't use a #6 cup with 3/32 tungsten, get at least a #8 or even a #10 so you get better gas coverage without the gas blowing out like an arc gouger. When outside welding even in still air I always ran about 20 CFM or more on my TIG torch but I was not buying the gas. Also look at getting a Gas Lens and cup rather than the standard collet body. The same collets will work with the gas lens but you need a different cup.
I will pick up a smaller tungsten and a different cup. and yes, the gas is sounds like a jet engine sometimes.
As for running reverse polarity, it did ball up the tungstend for sure but it provided a different arc. Still too strong
And I will continue with scratch start. I am just bummed that this did not work for thin stuff.
question to all, why do you tig thicker metals? What does this process provide that is not in MIG? I am assuming a cleanliness in the weld and its slow pace allows for a higher quality weld but....
   / Tig Welding Failure, what am I doing wrong #16
I only Tig weld fairly thin, or small objects. I Tig weld most aluminum, but I do have a spool gun for thicker aluminum. For large projects I use my Mig / wire feeder.
   / Tig Welding Failure, what am I doing wrong #17
Did you put the 3/8" bolt in the nut when you welded that nut in to avoid any warpage of the threads or just do it free with no problems?
   / Tig Welding Failure, what am I doing wrong #18
I Tig welded the nut just for an example. I also Mig welded one. Placing a bolt in the nut before welding is the way to go:thumbsup:, also could run a tap through the nut too.
   / Tig Welding Failure, what am I doing wrong #19
Sheild Arc; your welds are always a joy to look at.
   / Tig Welding Failure, what am I doing wrong #20
Thank you very much Egon! But I'm just a hobby welder.;)
2002 Wacker RD11A Tandem Smooth Drum Roller (A51691)
2002 Wacker RD11A...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
Lockwood 480 Pecan Harvester (A55315)
Lockwood 480 Pecan...
2014 TRAIL KING INDUSTRIES TRIAXLE RGN HG SERIES W/STINGER (A55745)
2014 TRAIL KING...
2006 Toyota Tundra 4X4 Pickup Truck (A53422)
2006 Toyota Tundra...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A55745)
2008 TEXAS BRAGG...
