Hiow do you change oil and hydraulic fluid without a mess?
   / Hiow do you change oil and hydraulic fluid without a mess? #21
You know - I looked at one brand, many years ago and things could have easily changed or the ones I looked at may have only been for cars/trucks. In any case, a good system could save you from the "hot oil up to the armpit" situation and the potential of stripping the threads on these new OEM plastic drain plugs.
Plastic drain plugs? What maker can think that's a good idea?
   / Hiow do you change oil and hydraulic fluid without a mess? #22
The new, improved OEM plastic fill/drain plugs are just another step forward into the world of modern technology, HA. My 2009 M6040 has a combination of five for the engine oil & hydraulic fluid fill/drain. Fortunately, those for the front diffy, front axel and front axel gear cases are still metal.
I just wonder how much money was saved on my tractor by going from metal to plastic on five plugs. Maybe its just my age showing.
   / Hiow do you change oil and hydraulic fluid without a mess? #24
What bean counter can think that's a good idea?
There, does that answer the question for ya? :laughing:
Kubota has always been so deliberate, cautious and smart. I don't get it and heck, they're out of California so that can't be the problem. I'm going to look under my M7040 in a few minutes and sure hope I see metal.
   / Hiow do you change oil and hydraulic fluid without a mess? #25
They all answer to the stock market, which wants results NOW, and does not care one bit about next year. Some companies hold out longer than others, but they all succumb, eventually.
   / Hiow do you change oil and hydraulic fluid without a mess? #26
I hit up the local furniture/appliance store for large cardboard prior to the fluid change.
   / Hiow do you change oil and hydraulic fluid without a mess? #27
Well, I checked and am pleased to report my M7040 has steel drain plugs. All the caps on top of the engine are plastic, however, and I wish they weren't but that part is OK. After thinking this through, I actually would not be totally upset by a plastic drain plug if it was made of the right material and it didn't have to last forever. I bet it would be OK, especially if Kubota thought it through..
   / Hiow do you change oil and hydraulic fluid without a mess? #28
Plastic has came a long ways hasn't it. When I was a kid, 1950s, I bought a plastic pocket comb. The teeth would break off when combing your hair and didn't have a chance in a jeans pocket. Try to break a tooth off a plastic comb now!!!!! :)
   / Hiow do you change oil and hydraulic fluid without a mess? #29
Once again I got it a little wrong. Like sixdogs - my DRAIN plugs are steel - the FILL plugs which are on top, are plastic. I had to go out and check. What made me check was I remembered how hot the drain plugs for the engine oil were last year. I don't think they would hold/retain heat so much if they were plastic.
   / Hiow do you change oil and hydraulic fluid without a mess? #30
I like to stick a permanent magnet on my wrench to keep the oil plug form ending up in the drain pail like often happened in the past. This wouldn't work to well with plastic. The plastic drain plugs on my RV work well but get rounded off if snugged to tight so Chanel locks come into play.
(9) 8' Treated Posts (A50515)
(9) 8' Treated...
2 Axle Trailer (TITLE) (A50774)
2 Axle Trailer...
Year: 2008 Make: Volvo Model: XC90 Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A51694)
Year: 2008 Make...
2016 Ford Transit 350 Cargo Van (A50323)
2016 Ford Transit...
AerWay Tillage Tool (A50514)
AerWay Tillage...
Kinze 3600 16 R Planter (A50514)
Kinze 3600 16 R...
