Adjusting hydraulic pressure relief valves on TYM 454 or other.
   / Adjusting hydraulic pressure relief valves on TYM 454 or other. #21
Did you get a chance to snap a pic so I could compare your valve to mine?
I still only have a flip phone and don't have text. I retired from a job in IT, crazy I know. Looking up under the tractor(right side) The adjustment screw is on the left side of the loader valve facing the rear of the tractor. Small allen wrench, small locking nut. Kind of hard to get to because my hand is fat and the hoses are in the way. :)
   / Adjusting hydraulic pressure relief valves on TYM 454 or other. #23
No problem, I'll snap a pic of mine and post it.
   / Adjusting hydraulic pressure relief valves on TYM 454 or other. #24
Been tied up so havent been able to get a pic until now.
First off , is this the valve with all the lines going into it?
   / Adjusting hydraulic pressure relief valves on TYM 454 or other. #25
Yes that's the valve, set screw is on back as your looking towards the bucket.. it's an Allen with a lock nut, I moved mine most of the way in(the pressure maxed out before the limit anyways) and it made a huge difference.. I tried to lift something that I estimate to be 400 lbs and it wouldn't pick it up all the way.. after adjusting screw it lifted a cat3208 engine that's supposed to be 1500 lbs.. so huge difference
   / Adjusting hydraulic pressure relief valves on TYM 454 or other. #26
Hmm, this is the only allen on the back of the valve, it is directly above the 2 silver cable inputs.
   / Adjusting hydraulic pressure relief valves on TYM 454 or other. #29
No, that's a plug on the extra port.. its behind those cables
What year is your tractor? Mine is a 2015, also it came with a back hoe.. I didn't get the back hoe but it was plumbed for the hydraulics for it. Possible that the valve is different because of those two variables?
my loader valve looks just like that even though mine is a lm45. I will look at mine again today but jim is right. It was hard to get to. could only move the allen wrench a little at the time.
2019 KOMATSU WA320-8 WHEEL LOADER (A51246)
2019 KOMATSU...
2016 FORD F250 XL SUPER DUTY EXTENDED CAB TRUCK (A51247)
2016 FORD F250 XL...
2016 JOHN DEERE 3032E LOT NUMBER 94 (A53084)
2016 JOHN DEERE...
ECHO SRM-2120 GAS WEED EATER (A51248)
ECHO SRM-2120 GAS...
(1) HD 27ft x 24ft Full Garage Kit Metal Building Frame (A51573)
(1) HD 27ft x 24ft...
DEWALT 3400 PSI GAS PRESSURE WASHER (A51248)
DEWALT 3400 PSI...
