Kubota BX25 Backhoe hydraulic adjustment
   / Kubota BX25 Backhoe hydraulic adjustment #1
bbaley
Yacolt, WA
Kubota BX25D
Hi all,
I have a BX25D with about 25 hours on it.
The backhoe is very fast, abrupt and "bouncy" side-to-side operation but smooth in all other axis and movements.
Is there any way to adjust or limit the side-to-side movement ONLY such that it is more in line with the rest of the bacjhoe movements/operation ?
I mean it shakes the whole rig with even the slightest smooth movement of the stick.
I can run a skid steer ok - so I get finesse/easy/small stick movements - and everything else on the BX - font loader ad backhoe is great - it's just side-side.
Anyway,
thanks for any ideas, opinions or slaps up side the head that help me learn :)
Does anyone else find their BX25 backhoe to behave the same way ? is it just "normal" ?
   / Kubota BX25 Backhoe hydraulic adjustment #3
What RPM are you working at? At 2200 mine works real smooth. At full throttle it gets faster and jerky. Of course I raised my Hyd pressure to 2000 PSI. Only real effect was lifting capacity. Once RPM reaches 2200 the lifting capacity increase is negligible. I hardly ever run past 2200 except with the Roto-Tiller and Brush Mower. No sense in making it scream for minor working affect.
Ron
Ron
I also usually run it 2200-2300
only over that - around 2500 if lifting logs or boulders with grapple. so far anyway.
it just seems to be very "jerky" at all speeds - unless it is so slow as to be too slow, like at idle.
I will try something lower 1900-2000 and see - It seems like I have tried a lot of rpms but will go through the range again and see if a sweet spot.
2014 COTTRELL CX-09LS2 AUTO HAULER (A51222)
2014 COTTRELL...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A51219)
2018 INTERNATIONAL...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
2016 CATERPILLAR 262D WHEELED SKID STEER (A51242)
2016 CATERPILLAR...
2019 CATERPILLAR D6 LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2011 ORTEQ ENERGY SERVICES 40 MANIFOLD TRAILER (A50854)
2011 ORTEQ ENERGY...
