Axles to store mower in a verticle position
   / Axles to store mower in a verticle position #1
Barneyhunts
Gold Member
Dimock, Pa.
Kubota L4240 Kubota B7800, Kubota BX2200
Several years ago I bought a pair of axles & wheels to store my Kubota 60" mower in a vertical position, from a vendor on this site and I can't remember the name. Can someone help me? I'm not sure if they're still available, but I find it a great way to store the mower.
Thanks,
Barney
Thank you Irod. Just what I'm looking for.
Barney
   / Axles to store mower in a verticle position #4
Barney
I have a set, highly recommended!
wrooster
   / Axles to store mower in a verticle position #5
Cool! I'll have to see if I have any spare shafts from things laying around to see if I can make my own.
   / Axles to store mower in a verticle position #6
I made a set of axles for the 60" mower for my B2650. I went to Lowes and got a 2 ft piece of 3/4" black iron pipe. Cut it to length, welded caps on the ends of the axle, drilled a 1/2" hole in the caps, welded 1/2" nut over the holes for the bolt to hold on the wheels. After I got the axles where I wanted them, I drilled a hole where the original pins went through the axle. Used the pins to hold the axle in place. Worked out really good. Very stable. I can pressure wash the underneath of the deck standing up on the new axles no problem. I had less than $25.00 in the whole thing.
   / Axles to store mower in a verticle position #7
A lot of us have done this and it's pretty easy once you measure the size of your sleeves for the axles. My only comment is that I have much larger wheels on the set I made for my JD 62D deck and I think that works better. Harbor Freight regularly puts pnuematic 10" wheels/tires on sale for $4 each and they work very well for this. They have a 5/8" axle hole. For my deck, 1/2 inch pipe worked and the ID is very close to 5/8 rod.
2018 MACK GU813 DUMP TRUCK (A59823)
2018 MACK GU813...
2016 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A60429)
2016 CATERPILLAR...
2020 DRAGON ESP...
pressure washer, and trailer (A56859)
pressure washer...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58216)
2011 MAGNUM...
Harlo HP6500 (A60462)
