Tractor Hydraulic Transmission Oil
   / Tractor Hydraulic Transmission Oil #51
We have several shops that work on diesel equipment [ dozers/TLB's/18 wheelers/tractors/etc... ]. They heat their shops with fuel oil. They dump the used oils into a 55 gallon drum, then pump/filter/mix it with the fuel oil they burn. Helps heat their shop and gets rid of the oil.... They are glad to get every drop of oil they can get to keep heating costs down.... Might look/ask around....
   / Tractor Hydraulic Transmission Oil #52
Hello, I have a new to me TC35 and need to change the hydraulic fluids, very interesting read.
My question is what do you do with the OLD removed fluids... I haven't read anything here on how to dispose of it.
Thank You
~Phil
Many places that sell it, take it. Might be limo to amount per day though.
   / Tractor Hydraulic Transmission Oil #53
Hi ok thanks ill ask. I know placew that use used motor oil in special heaters, i just didnt know they could burn hydro fluid...
   / Tractor Hydraulic Transmission Oil #54
One of the chain auto parts stores (Auto-zone) takes used motor oil. I asked a guy at the one closest to me if I could dump some used transmission fluid, he said "sure, motor oil, tranny fluid, and hydraulic fluid is all oil right?, go ahead". So I never asked again.
   / Tractor Hydraulic Transmission Oil #55
I have a oil quick change place that lets me dump 50 gallon at a time into their storage tanks.
   / Tractor Hydraulic Transmission Oil #56
Hydro oil is just oil. Usually cleaner than engine oil.
I'll be saving my future oil for my friend. Borrowed his 40 year old backhoe & the oil that was leaking out looks like a chocolate milkshake. Used oil out of my machine will be better than what is in that ancient beast & help keep it going a bit longer. Some of the pins have a 1/4" of slop & the thing isn't worth putting a lot of money into.
   / Tractor Hydraulic Transmission Oil #57
I let the "heavies" settle out of it in pails, then mix it 50/50 with diesel and filter it. It then gets used for fuel in one of my tractors...
SR
   / Tractor Hydraulic Transmission Oil #58
Thank You
~Phil
Here is it a year later and I scanned through many oil threads and to post #50 in this thread for an answer to this question.
Ken
   / Tractor Hydraulic Transmission Oil #59
Any place that does oil changes will take it , wally world , some auto part stores
   / Tractor Hydraulic Transmission Oil #60
In Ma, anyplace that sells oil has to take the old oil.
2018 Ford Fusion Hybird (A53424)
2018 Ford Fusion...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2001 Acura MDX SUV (A53424)
2001 Acura MDX SUV...
2022 CATERPILLAR 242D3 SKID STEER (A51406)
2022 CATERPILLAR...
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
