Electric Cars: Chev Bolt seems to be the first practical one.
Status
Not open for further replies.
   / Electric Cars: Chev Bolt seems to be the first practical one. #31
No fair citing real-world experience to counter that rant.
You aren't the idiot ....
Don't own a hybrid or electric but would consider one in the future .
I see the Prius IS still rated the most reliable car- and has been for Many years by Consumer reports...
2016 model they averaged 52 MPG overall, not bad even- if they are not the best looking car
   / Electric Cars: Chev Bolt seems to be the first practical one. #32
I didn't realize they had an all-electric car called the bolt. I thought their all-electric was the spark, but I see now that it has a gas engine. Why would you call a car a "spark" and it not be an electric car?
If I was going to buy an electric car it would have to be the volt, at least then you can recharge it on the go. I couldn't imagine having to wait for a car to charge on a road trip.
On a side note, I did notice a few weeks ago that the nearby gas station where I buy my ethanol-free gas and off-road diesel now has an electric charging station.
Volt does not fully charge the battery pack while on the gas engine . Mountain mode will charge to 20-30% iirc plus what ever regenerative braking adds.
The Volt requires utility power to charge.
   / Electric Cars: Chev Bolt seems to be the first practical one. #33
Heat is not big problem I suppose. The electric motors generate some heat. In fact, the Tesla motor is water cooled. If the motor uses 50 kW and has 97% efficiency there is 1.5 kW of heat that can be used to heat the car. I need to reserach the AC but I think it should't be a problem either. My house of 2500 sqft has 5 kW compressor. Car is about 25 sqft so even with less insulation AC shouldn't be a big hit on energy comsumption.
Since the AC in electric cars is stand alone unit it could be powered by solar integrated into the car roof and work even when the car is parked. Wouldn't you prefer to get into precooled car at hot summer day? And you could leave your baby or dog in the car too.
There is not enough area on the roof of a EV to place enough solar panels to provide any useful charge. Even when not parked in the shade and the sun directly over head.
The "heat" recovered from the motor, inverter and battery pack is low quality due to the low temperatures. Not enough to defrost or defog windows in the winter.
   / Electric Cars: Chev Bolt seems to be the first practical one. #34
Just call me an idiot. :laughing: I've been driving electric for 15 years, and both cars performed flawlessly, required zero maintenance, and saved me significant ownership dollars. :thumbsup:
Zero maintenance ? Saved ownership dollars, how ? Are you comparing an EV to a mid 1970's big block pickup truck ?
   / Electric Cars: Chev Bolt seems to be the first practical one. #35
My arithmetic says 50 kW is about 67 horsepower. I doubt the car uses that much power when cruising down the road. As I recall, about 1/10 of that is required for the typical car.
Good point, the Bolt's battery is rated for 60Kwhr which would operate hot and last maybe 30-35 minutes with a 50Kw load. The charge discharge system doesn't even fully charge or discharge the battery pack to extend service life. 12-15kw per hour for three hours is about max.
   / Electric Cars: Chev Bolt seems to be the first practical one. #36
I was initially excited about the Bolt,,,,,that is until I saw the price. Even at the taxpayer robbed price. The Volt costs about the same.
Even if I got free electricity, It is no where cost efficient overall.
It is not even half the car that a Tesla is.
I had an electric golf car,,,once. After the 2nd set of batteries went out, I sold it. Have a gas powered gator now. Never looked back.
Agree the Tesla is a far better car. But Bolt is similar capabilities at 1/3 the price.
It's sort of the modern equivalent of the 6-cylinder rubber-floormats $1.900 versions of cars of the past. (You could order a 55 Chev coupe with no back seat!). If all you need is to haul your butt around and elegance means nothing - then why not build for that market too?
   / Electric Cars: Chev Bolt seems to be the first practical one. #38
Medium size car requires about 30-35 HP or 23 - 27 kW to travel at 65 mph on a level road. The actual power necessary is higher due to the road not being always level and the speed also varies. So the 50 kW is somewhat high but still a reasonable estimate. The energy consumption increases linearly with the size of the car (provided the aerodynamic drag coefficient is the same). Also, the energy consumption increases with cube of speed. In other words to double the speed of a vehicle the power necessary (and fuel consumption) increases eight times.
In the example, Bugatti needs about 1200 HP to reach 266 mph. 133 mph would then require 1200/8=150 HP and 65.5 mph would require 19 HP. Needless to say, the Bugatti is a car with small frontal area a low drag coefficient.
   / Electric Cars: Chev Bolt seems to be the first practical one. #39
I was not talking about charging batteries but cooling the car. My estimate is, if 5kW keeps my house (24000 cuft) cool, AC for much smaller car (80-100 cuft) probably doesn't require gobs of power. Roof panel could generate about 200 W. Don't know if it is enough to keep the car cool. I just google it. It takes about 0.25 HP on low and about 6 HP on max.
   / Electric Cars: Chev Bolt seems to be the first practical one. #40
It all depends on how far you commute. I figured the break-even point for us is about 4 years at gasoline cost 2.80/gal.
Status
2008 Godwin Dri-Prime CD103M Towable Trash Pump (A59228)
2008 Godwin...
2014 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
2018 CASE 340RT TRACKED TRACTOR (A60430)
2018 CASE 340RT...
2017 Bobcat T770 Compact Track Loader (A56438)
2017 Bobcat T770...
GMC 2500HD 4wd Service Truck (A56438)
GMC 2500HD 4wd...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
