Advice on potential purchase (Nortrack 3500B)
   / Advice on potential purchase (Nortrack 3500B)
   / Advice on potential purchase (Nortrack 3500B) #83
I think they are steel castings but should be forgings. Yes, it must maintain it's original shape to allow it to move freely through the gates. You could have a new piece machined from tough billet steel and welded to the ball. Did you try Circle-G?
   / Advice on potential purchase (Nortrack 3500B) #86
Fortunate the piece didn't wipe out the gears.
I've seen people adapt shift levels from other cars to work... one guy even made one from a Model A Ford lever and Model A's use a lot of forged steel.
Tool and Die makers can buy threaded balls and you might be able to source one that could be threaded to the old shaft.
None of the above would be as cheap as finding an OEM
Thanks!!!!
I knew you would respond Bob!!!
I am extremely lucky it didn't wipe out the gears. I had to fish wish a magnet last night, in the dark and raining just to get the sheared off end out of the transmission case.
It was wonderful.
I am ordering the part now!!!!
Bob, check out my JD 1020D thread. I love 3 cylinders diesels, but I guess I don't have a choice lol.
Also Bob I read on another forum about another gentlemen who had this happen to his Yuchai Dozer. He was barking a lot about some of the issues he was dealing with on his Dozer.
He made a good point that the plates where the gear selector shaft ball moves around to select each gear should be filed down. The plates edges are sharp, and are def. what caused the shaft to shear off after hours of use.
   / Advice on potential purchase (Nortrack 3500B) #89
Don't know of the other fellow. Most of the folks I know of are pretty satisfied with their Yuchai's. But then there are the ones that would gripe even if they were hanged with a new rope. Lol.
   / Advice on potential purchase (Nortrack 3500B) #90
This would be a good thing to check when a dealer does a pre-delivery service, although now I have over 700 hours on mine. Maybe I'll pop one of mine out for inspection.
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2014 Infiniti QX60 (A51694)
2014 Infiniti QX60...
2015 Ford Focus (A51694)
2015 Ford Focus...
John Deere 1110 Field Cultivator - Heavy-Duty Soil Finisher for Precision Tillage (A53473)
John Deere 1110...
2021 MDB TF150R 84" HYD MULCHING HEAD (A51406)
2021 MDB TF150R...
2011 Mercedes Benz Sedan (A51694)
2011 Mercedes Benz...
