Hey Bob,
I seemed to have misplaced my manuals.
That being said I would like to tighten my tracks/make a track adjustment.
Can you provide me with a quick rundown on how to perform this? What to turn, etc.?
Drive the tractor forward for about six feet to get the slack on top. Wire brush and apply penetrating oil to the threads of the yoke rod that extends into the spring cylinder (if you have been greasing that fitting it should go easy) then, turn the nut on the yoke rod counter-clockwise to extend the rod. However, bear in mind that track tension is controlled by the spring, not the adjustment. Should achieve about 1" to 1-1/2" of slack between the sprocket and top carrier roller. Don't over-tighten, you need that spring travel to keep from breaking the final drive shaft from debris caught between tracks and sprocket. If only these machines had carrier covers and decent rock guards, but they don't.
Can the Dozer be sitting on the ground? Yes, it must be. Do not suspend it in the air.
Thanks!!!
