Thinking of changing R4 over to R1
   / Thinking of changing R4 over to R1 #1
Kubota 2007
PA
Kubota L4740,B3030,ZD326, RTV900,L4200 1120RTV,L4310 & KXO4-5.JD 310SG,310J,JLG 450AJ. 0-5
I Have a L4740 with 170hrs , ordered it with R4's and I'm not happy. I'm think of selling them, fronts are Titan 10-16.5 6ply w/rims, rears Titan 17.5L-24 6 ply w/ rims (no center disk) All look as if new, rears are loaded with W/S. I'm thinking I should get $1500.00 for everything, does that sound fair? I priced new rims and R1 tires and I'm over $2,000.00 and still have to load them.
   / Thinking of changing R4 over to R1 #2
I want to do same on my l5030, but never did.
   / Thinking of changing R4 over to R1 #3
You will like the traction mostly damp areas,just have to be tad careful when making tight turns R1's will loosen soft ground even more.
   / Thinking of changing R4 over to R1 #4
I have no idea what you will get for you R4s, but I do know you will like the extra traction with R1s.
R4s have their place, particularly on industrial equipment. For my use in a rural agricultural and woodlot setting, R4s only have the traction of worn down R1s. Although tire chains on the R4s make a huge difference.
   / Thinking of changing R4 over to R1 #5
Biggest mistake I ever made was getting R 4 's on mine when I bought it. If the cost was not so much I would go with R 1's in a heartbeat
   / Thinking of changing R4 over to R1 #6
Have you priced just the tires with transferring fluid and keep your existing rims? It might be easier to sell R-4s without rims because the buyer wouldn't have to buy rims.
   / Thinking of changing R4 over to R1 #7
I think R4's require a different rim.
R-4's vs R1's do have a different rim, front and rear.
   / Thinking of changing R4 over to R1 #9
I would definitely think hard about buying R4s again. They work, but not great and the turf tear-up isn't that much better with them vs. the R1s.
   / Thinking of changing R4 over to R1 #10
Do you have a FEL on the tractor?
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A57454)
New/Unused AGT...
2007 MACK GRANITE CV713 DUMP TRUCK (A60430)
2007 MACK GRANITE...
2000 FORD F-550 XL SUPER DUTY DUALLY SERVICE TRUCK (A60430)
2000 FORD F-550 XL...
2013 Infiniti G37 Coupe (A59231)
2013 Infiniti G37...
2016 KOMATSU D65PX-18 BULL DOZER (A58214)
2016 KOMATSU...
2023 MORBARK WOOD HOG 3400 XT HORIZONTAL GRINDER (A60429)
2023 MORBARK WOOD...
