Little Z is throwing the belt...
   / Little Z is throwing the belt...
Perfect timing....belt just came off my z122r yesterday again. Dealer installed belt keepers due to recall last year. Guess it didn't help. Not a huge issue....I have faith in my local dealer to correct the issue. Showed up with a loaner mower and took mine back to the shop....ON A SUNDAY!!!
   / Little Z is throwing the belt... #12
Didn't know there was a recall on these. I'd better check with my dealer. Thanks for posting.
There is an "updated belt guide and tensioner" for the Z122R I've just learned from the dealer.
   / Little Z is throwing the belt... #14
Do you have any more information about this? Like maybe a part number for the z122r? i recently acquired one and would like to get the new tensioner part ASAP.
   / Little Z is throwing the belt... #15
I purchased my Z122R last spring. Only 32 hours on it and had to replace the belt 3 times! My dealer said that he contacted Kubota regarding the problem because every one he sold are doing the same thing. Kubota's response..."We don't recognize a problem" what a bunch of BS! Dealer is very frustrated and has done everything he can on his own to correct it. ie: installed belt guards, adjusted tensioner and pulleys etc. I just got it back from them for the third time and it still continues to smoke the belt! Frustrating!!!
   / Little Z is throwing the belt... #16
I took mine to the dealer and they installed a recall belt keeper, but it was the wrong one and my problems continued. Apparently, it's a different part from the other deck widths. Since then, it's been solid and no issues.
   / Little Z is throwing the belt... #17
So are you saying Kubota has a fix for the problem? If there is a recall on this model, should Kubota not notify the owners of it?
   / Little Z is throwing the belt... #18
I don't know who Kubota should notify, but my dealer knew there was a service bulletin and he got the parts to fix the problem. Kubota knows, and they've let the dealers know. There is a service bulletin out there on it. I'd call some different dealers to get the information if yours is not up to speed.
   / Little Z is throwing the belt... #19
Ok👍 Thanks, Tex, I'll check it out, I appreciate that. Not sure if I'm getting the runaround up here because I'm in Canada so you would think the policy would be the same as the US, but you never know lol!
   / Little Z is throwing the belt... #20
I would like to get that product service bulliton from Kubota and show it to my dealer though!
BELSHE DT-235 (A53843)
AUCTION STARTS HERE @ 9AM (A52706)
AUCTION STARTS...
2008 CATERPILLAR 272C SKID STEER (A52705)
2008 CATERPILLAR...
New/Unused 20,000lb Electric Winch (A54865)
New/Unused...
2015 Ford F-350 Utility Flatbed Truck (A51692)
2015 Ford F-350...
New/Unused CFG Industrial MX-CRT23 Mini Skid Steer (A54865)
New/Unused CFG...
