leonz
Super Member
You should purchase that one as the coming year has more of the pollution control garbage and have them add the dual rear remote option or three remotes if possible as you will have a better equipped mule.
A smaller front mounted plow on the loader is an option with a SSQA plate AS LONG AS you have the plow set up with the heavy plow depth gauge discs or heavy pneumatic casters to let it ride on the road surface.
If you expect to use a snow plow you will need chains and loaded tires. The turf tires with V bar chains will be a much better traction option for you. The snow plow will have also have a complete separate underframe mount for it as well so keep that in mind.
AND understand that if you do not have V bar chains for the tires you can plan on getting really stuck and I mean stuck.
A rear mounted snow blower does not require mounting frame and will cost you less money than a front mounted snow blower (I absolutely hate my front mounted snow blower as it is junk and a money pit) versus the simpler rear mounted units.
You have to remember that the snow plow is going to make walls of snow that will eventually freeze where a rear mounted snow blower will get rid of all the snow all the time.
