Brother's wife says buy something to do the job but what?
   / Brother's wife says buy something to do the job but what? #11
Might be a plan ...
Is he just mowing trails, or is he cleaning up the wooded areas as well?
Is the minimum width of his trails 40"?
If he could mow 80%-90% of his needs with a 4' or 5' mower, then do that and use the DR walk behind for the rest.
He could get a 48" cutter for his Deere 4310 which is 50" wide.
I had a 15hp Shibaura with a 48" cutter and it did amazing work, but I will admit to puckers on side hills!
Max width is 40"
Thanks for the ideas so far. It's not really trails, its cleaning up areas such as an area that was selectively cut and trees are fairly close together. in some replanted areas on the edges. and just generally keeping the blackberrys at bay. There is some thought that maybe as big as a 48" with final work with the old DR may be the answer. And yes he does like to do it, it's just that it's not as easy as it used to be.
   / Brother's wife says buy something to do the job but what? #13
I believe Steiner had a rough cut mower that was narrower than the 60 inch, but not sure if Ventrac picked them up.(then again, I may be dreaming, lol)
David from jax
   / Brother's wife says buy something to do the job but what? #15
Have him buy one of these lol, fit it with knobby tires
   / Brother's wife says buy something to do the job but what? #17
   / Brother's wife says buy something to do the job but what? #19
My brother has about 50 acres mostly wooded. some recently logged some reforested several years ago.
He likes to keep things trimmed up and has been using a DR walk behind 30" rough cut for years.
He has hills and soft spots. We are in the northwest so grass and weeds grow quickly and it rains a lot.
Anyway his wife has told him he has to get something that doesn't work him so hard.
He has a 4310 John Deere which is way too big for this work.
The problem is he says max width is 40".
My suggestion was a Steiner/Ventrac. Problem is narrowest mower is 60"
Even a Kubota BX only narrows to 44"
Budget is max $20k.
Suggestions please.
Tell her the DR has the edge, and keeps the old guy from needing a membership to the gym!
   / Brother's wife says buy something to do the job but what? #20
Heil V-1722 28Yd Front Loader Garbage Truck Body (A51691)
Heil V-1722 28Yd...
2025 New/Unused Wolverine 3 Point Quick Hitch (A51573)
2025 New/Unused...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53472)
NEW HOLLAND 706 30...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2022 K-Z Sportsmen 260BHSE 28ft T/A Travel Trailer (A51694)
2022 K-Z Sportsmen...
