Kubota 80 Series Hydraulic pressure tester
   / Kubota 80 Series Hydraulic pressure tester #12
OK, it definitely is a 5/8" connector. Here are some pictures after I removed the FEL to get some. Going to do some more web surfing to see if I can find an easy way to build one. In simple terms, I just need a connector, a hose and a pressure gauge. The hose and gauge seem simple to find. It's finding a connector I can attach to a hose that seems to be the hard thing to find.
Dell, what do you think of this coupler... should be easy to find an adapter to install a gauge on it.
5HTF6 | 5/8" Female Coupler, 3/4" NPTF Threads
   / Kubota 80 Series Hydraulic pressure tester #13
So you attached it directly to one of the FEL lines? If so, which one and where? :)
IMG_6106.JPGi unscrewed the fitting with the white washer on it an attached my pressure test line. Then capped off the line I took off. The fitting you will take out will have a o ring seal on it. IMG_6108.JPGIMG_6116.JPG
   / Kubota 80 Series Hydraulic pressure tester #14
Do you have part numbers and also where you bought the pieces to make this tester...?
I don't have part numbers as some were fittings I had from other machines an the hydraulic lines an quick connections I took off of the 4way dozen blade I have from when I had my bx25.
   / Kubota 80 Series Hydraulic pressure tester #15
   / Kubota 80 Series Hydraulic pressure tester #16
Guy`s,
dosen`t the BX23S only have one hydraulic pump that runs the entire tractor...??? Is there any reason you couldn't test the pressure at the rear couplers that run the backhoe...??? Seems like its alot easier to test it there, and no manifold to worry about like the FEL has. I`ll get some pictures of the couplers, male & female ends and post them in here, there ARE parker part numbers stamped right in the couplers. As for the front loader manifold/couplers, i dont see any part numbers anywhere for just the couplers, they do say MADE IN INDIA though. Somebody somewhere has to have these flat faced couplers available. I dunno, maybe i`m not thinkin this thru to well... but its worth a shot.
Ok, i was not able to load the pictures of the couplers from my BX23S, but the coupler part numbers are:
I took these numbers right off the couplers at the backhoe, where the 3point hitch top mount is located.
PARKER
FEM-252-4FP-1076 (Male End)
PARKER
FEM-251-4FP-NL-1071 (Female End)
They look to be either 1/4 or 3/8 pipe threading (???) but i`m not good at guessing pipe thread sizes to well, unless they`re bolts...lol.
Anyways.... thoughts....?????
Found some couplers... better off getting the male end, its half the price of the female end (Go figure, females always cost more...lol)
Parker Coupler Body, 1/4-18, 1/4 In. Body, Steel FEM-251-4FP-NL | Zoro.com
Parker Coupler Nipple, 1/4-18, 1/4 In. Body, Steel FEM-252-4FP | Zoro.com
   / Kubota 80 Series Hydraulic pressure tester #18
I don't understand why these links to Trausch Dynamics don't link right to the product but seem to always go back to the menu.
Yeah whats up with that, i just tried it, same problem here.
Well at least i posted a couple other links that takes you to the correct couplers at ZORO. com (see post #16)
Gall dangggggg, that female coupler is pricey....!!!!!! The male coupler is almost half the price.
Guy`s,
PARKER
PARKER
I could be totally wrong about this, but my guess the flow goes from the male connector to the female. Therefore, you would need to get the female connector and use that for the tester? I wonder if the female connector could also be used for the front? I would hate to think that Kubota used different connectors on the tractor.... but you never know.
I just hope that someone soon figures this out and lets the rest of us know! haha :)
   / Kubota 80 Series Hydraulic pressure tester #20
Tractor Dell, I notice that the gauge you mentioned in the first post goes to 3000 psi. What pressures are you expecting to see?
rScotty
NEW Skid Steer Bolt on Hay Forks (A53002)
NEW Skid Steer...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52576)
2018 FREIGHTLINER...
2018 Nissan Titan Pickup Truck, VIN # 1N6AA1E57JN515039 (A51572)
2018 Nissan Titan...
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
FAE UML/SSL 150 VT QUICK ATTACH HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
2019 RBR Venturi 380 (A52748)
2019 RBR Venturi...
