Does a power beyond port kit block the tank port on loader control valve? Brand LV22R
   / Does a power beyond port kit block the tank port on loader control valve? Brand LV22R #1
sghpi1
charleston
1999 Earthforce
i installed a power beyond kit to power my backhoe and outriggers on a 1999 Earthforce tractor. it appears that screwing in the power beyond port kit blocks the tank port. this is on a brand hydraulics LV22RFSTKA2B. If so where would tank port go?
thanks
   / Does a power beyond port kit block the tank port on loader control valve? Brand LV22R #2
thanks
There is two in ports and two out ports. The power beyond is screwed in to the end of the valve on the out end of the valve. There are six ports on the face. Two for boom and two for the bucket. One of the remaining two ports is an in port and the one perpindicular to the power beyond plug can be used as a tank port.
using the picture, If I hear you correctly then the outlet port next to A2 can still be used as an outlet port?
   / Does a power beyond port kit block the tank port on loader control valve? Brand LV22R #4
thank you i guess the kit doesn't block the port totally and allows for ample fluid flow to tank.
Everything is working as it should, this valve isn't as heavy or as impressive looking as original but works and is a way better deal than resealing. only if it can be mounted and the old hoses work and the knob works without hitting anything, otherwise it could be a real nightmare.
   / Does a power beyond port kit block the tank port on loader control valve? Brand LV22R #7
Many of those PB plugs simply separate the tank line from PB.
2003 Land Rover Discovery 4WD SUV (A59231)
2003 Land Rover...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
Massey Ferguson 92” PTO-driven rear-mount snowblower
Massey Ferguson...
Brent 420 Grain Cart (A56438)
Brent 420 Grain...
2012 Ford F-250 Pickup Truck (A55973)
2012 Ford F-250...
2021 Harley-Davidson FLHP Road King Motorcycle (A59231)
2021...
