Does a power beyond port kit block the tank port on loader control valve? Brand LV22R
   / Does a power beyond port kit block the tank port on loader control valve? Brand LV22R #1
sghpi1
charleston
1999 Earthforce
i installed a power beyond kit to power my backhoe and outriggers on a 1999 Earthforce tractor. it appears that screwing in the power beyond port kit blocks the tank port. this is on a brand hydraulics LV22RFSTKA2B. If so where would tank port go?
thanks
   / Does a power beyond port kit block the tank port on loader control valve? Brand LV22R #2
thanks
There is two in ports and two out ports. The power beyond is screwed in to the end of the valve on the out end of the valve. There are six ports on the face. Two for boom and two for the bucket. One of the remaining two ports is an in port and the one perpindicular to the power beyond plug can be used as a tank port.
using the picture, If I hear you correctly then the outlet port next to A2 can still be used as an outlet port?
   / Does a power beyond port kit block the tank port on loader control valve? Brand LV22R #4
thank you i guess the kit doesn't block the port totally and allows for ample fluid flow to tank.
Everything is working as it should, this valve isn't as heavy or as impressive looking as original but works and is a way better deal than resealing. only if it can be mounted and the old hoses work and the knob works without hitting anything, otherwise it could be a real nightmare.
   / Does a power beyond port kit block the tank port on loader control valve? Brand LV22R #7
Many of those PB plugs simply separate the tank line from PB.
2022 CATERPILLAR D3 CRAWLER DOZER (A60429)
2022 CATERPILLAR...
2017 CATERPILLAR 420F2 IT BACKHOE (A60429)
2017 CATERPILLAR...
2021 Kubota SVL75-2 Track Loader (A56438)
2021 Kubota...
2014 Lamar Pipe Trailer (A60460)
2014 Lamar Pipe...
2005 JOHN DEERE 160C LC EXCAVATOR (A52709)
2005 JOHN DEERE...
Amada M-3060 Mechanical Metal Shear (Japan) (A59213)
Amada M-3060...
