Oil & Fuel Raw gas in cylinders
   / Raw gas in cylinders
Thank you.
I have the 135 runing smooth like it should. # 2 and #3 cylinder were not firing hot enough to burn the raw gas be cause of crossed plug wires and carb out of adjustment. Also the timing was off. Thank you so much for your input.
   / Raw gas in cylinders #14
Do I have to remove the distributor to get the starter off? Seems that way to me.
1953 Massey ferguson 35 4 cylinder
Rotate the starter until the Bendix gear is facing outwards.
   / Raw gas in cylinders #15
Update. I got the 135 runing like a charm!! # 2-3 spark plug wires were crossed. Also the timing and carb were not right. The raw gas was from # 2-3 not burn the gas. Thank you guys for the input I am so thrilled the seebthis tractor going again!
Good to hear that the raw gasoline fix was easy and cheap.
2011 Chevrolet Impala Sedan (A51694)
2011 Chevrolet...
2025 Mower King SSBM72 (A50123)
2025 Mower King...
Gravely Compact Pro Zero Turn Mower (A53117)
Gravely Compact...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
2003 Volvo S60 Sedan (A53117)
2003 Volvo S60...
