Oil & Fuel Raw gas in cylinders
   / Raw gas in cylinders
Thank you.
I have the 135 runing smooth like it should. # 2 and #3 cylinder were not firing hot enough to burn the raw gas be cause of crossed plug wires and carb out of adjustment. Also the timing was off. Thank you so much for your input.
   / Raw gas in cylinders #14
Do I have to remove the distributor to get the starter off? Seems that way to me.
1953 Massey ferguson 35 4 cylinder
Rotate the starter until the Bendix gear is facing outwards.
   / Raw gas in cylinders #15
Update. I got the 135 runing like a charm!! # 2-3 spark plug wires were crossed. Also the timing and carb were not right. The raw gas was from # 2-3 not burn the gas. Thank you guys for the input I am so thrilled the seebthis tractor going again!
Good to hear that the raw gasoline fix was easy and cheap.
2025 K732 UNUSED Flower Bed (A53117)
2025 K732 UNUSED...
2001 MONACO KNIGHT MOTOR COACH RV (A53426)
2001 MONACO KNIGHT...
2008 Ford F350 XL, Diesel Dump Bed w/Spreader Box (A52384)
2008 Ford F350 XL...
Adams 5 ton Fertilizer Buggy / Wagon (A53473)
Adams 5 ton...
2006 International 4400 Lift All LOM15-55-1S 60FT Material Handling Bucket Truck (A51692)
2006 International...
City of Buckhannon - 2005 Volvo Garbage Truck (A52384)
City of Buckhannon...
