Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #861
Loses data signal......internet is gone.
Signal light goes off.
WHEN I have a data light I've seen only 4 bars. You have to go into the unit via browser .
I've powered cycle unit many times. I've done master resets a few times.
WHEN It does this it's a plastic brick.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #862
Its been mentioned a couple of times, and excuse me if its been said before, but have you disabled the time out?
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #863
Yes power saver turn off
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #864
A reflash might fix it. Dang sure worth a try if zte will provide the info.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #865
I thought that's what a master reset would do.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #866
A master reset isn't the same.
Zte wouldn't give me the 1.0.1 firmware. Said it's carrier specific.
I'd call (vs chat) and try again. Or chat zte and prove that won't work, THEN call att back.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #867
Neither ATT nor ZTE is (most often) helpful or knowledgeable when contacted by any means. My Mobley also has issues (sometimes loses Internet while both lights stay green, sometimes TV connects but my computer won't).
I'm not surprised. My wife replaced her Samsung Galaxy Light with a ZTE and it had so many strange problems she went back to the Samsung (a new battery resolved the Samsung's rapid battery drain issue - so it was the battery not the phone as it turns out.)
I'm not sweating it and stressing over what can't be fixed. I live (stress free) with what I've been handed.
When it works, it works well. When it doesn't work, fiddling for 15 minutes gets it working again. I have 1.5 Mbs as a backup, so a perfect Mobley is not a requirement for me.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #868
I see it the same way....EXCEPT.....fiddling with it for 15 minutes gets me no where. Last outrage was 2 days long, and when the at&t person did a refresh connect it came back instantly. Problem is I can't do it. It took the call. It's been up solid for 2 days now after that. Unpredictable.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #869
I opened mine up to find the antenna connection. Not sure i found it. Now it wont connect to att.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #870
Ingersol Rand 175 Air Compressor (A50774)
Ingersol Rand 175...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
Generac 5000Watt Heavy Duty Diesel Generator (A51691)
Generac 5000Watt...
2004 Stage Line SL-250 Mobile Folding Stage Trailer (A50324)
2004 Stage Line...
2004 Caterpillar 345B Hydraulic Excavator (A50322)
2004 Caterpillar...
