What is the best drill press for metal and how do you dril
   / What is the best drill press for metal and how do you dril #21
A good way to increase the accuracy of holes without spending a lot of $$ is to invest in a set of center drills (spotters work fine also, just need more). Use them to start your holes; good to make a habit to use on all sizes, especially on anything small (less than say .400) where twist drill point often deflects.
Center drills are great to use. A short cut I use is a center punch. Mine is on a hammer handle, a repurposed hammer that I had made for blacksmithing.The bit finds the mark and does not drift. - A center drill is a pleasure to use when I can find it!
   / What is the best drill press for metal and how do you dril #22
I have a Bridgeport clone knee mill that I use for drilling all the holes I need. I also have an old Buffalo Forge #15 benchtop drill press that I got in a swap for some machining work. It's between 55 and 60 years old and is still easily an order of magnitude better in quality than the usual consumer grade fare you find today.
   / What is the best drill press for metal and how do you dril #23
   / What is the best drill press for metal and how do you dril #24
As one said above, CLAMP your work, especially if it's thin material. A 6" piece of sheet metal spinning at 200 rpm will slice the crap out of you. Unplug the drill press when changing speeds if it uses step pulleys for speed changes. Always wear safety glasses. I never wear gloves when drilling, others may have a different opinion on that. That's just how I was taught. Machine auctions are a great place to get nice heavy equipment at bargain prices.
Kevin
   / What is the best drill press for metal and how do you dril #26
hey i like that idea of using that electrical box to hold the oil. mine keeps falling away.
   / What is the best drill press for metal and how do you dril #27
Where are you guys finding these 3 point hitch drill presses? :D
Bruce
:D:D:D
   / What is the best drill press for metal and how do you dril #28
On the "sorta" cheap side, this one goes down to 200 rpm
13 in. 16 Speed Drill Press
With a 20% off coupon it'd be $225. Would work for drilling maybe up to 3/4" holes in 1/2" mild steel as is, and if you're handy enough you could probably adapt this motor
Depending on how accurate your bigger holes need to be, hole saws can work OK - I've cut 2-1/2" holes in 3/4" steel using them at slowest (180 rpm) speed (normal 12-speed Taiwan DP) and a CONTINUOUS stream of compressed air cooling them - messy but doable. A "magnetic broom" can help afterwards with cleanup, like one of these
It'd probably help if you told us more about your actual NEEDS; material thickness, hole diameters, and more accurate price range than "poor" (my definition ain't the same as Bill Gates', for example :confused:) ...Steve
I have an early bench model of this DP. I have not detected any slop in the mechanisms. I like the 180 rpm for large holes. I have drilled up to 1" using cobalt bits (set 1/2-1 in 1/16 increments). Drilled up to 3" using hole saws. Some of these are up 1" thick steel stock. I work up to size needed in three jumps starting with a 1/4 pilot bit. I have even done some end mulling with a HF milling vise. For DP considered junk that I paid $45 for at the auction (only bidder) it has done a super job. I probably have $750 invested in accessories and various drills, mills, vises for up to 8", fence and etc. I only work at high speeds with HS bits up to 3/8 then start turning down. I always bolt my vises down, seldom don't anchor the work (maybe long or irregular pieces) support the other end of long pieces. I keep my DP level and bolted down. That way I can get true holes at right angles to the stock. I use plumbers sulfur bearing cutting oil liberally. I have an old Audel's machinists handbook I would not do w/o. Hope this helps.
Ron
Butler MFG Water Tanker (A56436)
Butler MFG Water...
2019 CATERPILLAR 305.5E2 CR EXCAVATOR (A52709)
2019 CATERPILLAR...
2007 STERLING LT9500 MIXER TRUCK (A58214)
2007 STERLING...
RING 2 STARTS HERE @ 9:15 AM (A58375)
RING 2 STARTS HERE...
2198 (A58376)
2198 (A58376)
2020 Deere 325G (A57148)
2020 Deere 325G...
