Leak in fairly new Baileys Chief 3 spool valve
   / Leak in fairly new Baileys Chief 3 spool valve
triple/quadruple database error!
   / Leak in fairly new Baileys Chief 3 spool valve #26
Looks about right. Just get the right hose length for the T port to the manifold.
Whatever you need to remove the pipe fitting.
Looks as though they got a hose with -10 JIC ends, and needed a way to adapt it to -08 at the manifold. And thats all they could come up with.
Depends on how bad the hose is damaged/kinked, and if within budget, just get a new hose to replace that one with -08 ends instead of -10 (just like you are going to do for the tank hose)
And get a second -10 ORB x -08JIC 90* fitting to install at the valve.
(basically make both hoses going to the manifold block the same)
So I'd get 2 hoses with -08 ends (whatever length needed probably closer to 3')
2 of the 90* fittings for the valve that go down to -08
1 tee.
   / Leak in fairly new Baileys Chief 3 spool valve #27
This sundat morning database error for the last 3 weeks in a row makes it a PITA to help a guy out:mur:
1 tee.
Pipe fitting is out as is the "P" hose. Which is only about 6' or so. So now the BOM for the Tank hose reflects that now, with -8 fittings. The "P" hose is fine, so I'll stick with it. All hoses are NPT male (what a PIA).
And I did confirm that the tractor hydro block has -8 fittings (nut size = 7/8") and the main port sizes on the valve are -10 (1" nut size). The working port hoses are all -8.
   / Leak in fairly new Baileys Chief 3 spool valve #29
Replying now to see if this stops showing up as an unread thread and to see if I can actually view page 3 now
   / Leak in fairly new Baileys Chief 3 spool valve #30
^^^that didn't work
But this post did ironically:mur:
2014 Ford F-150 Pickup Truck, VIN # 1FTFW1CT4EKG42947 (A51572)
2014 Ford F-150...
2012 Club Car Carryall 1 Utility Cart (A51691)
2012 Club Car...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
2016 JOHN DEERE 8245R LOT NUMBER 182 (A53084)
2016 JOHN DEERE...
JOHN DEERE 5075E LOT NUMBER 30 (A53084)
JOHN DEERE 5075E...
PRO WORKS PWFF LOT NUMBER 156 (A53084)
PRO WORKS PWFF LOT...
