Indestructable Rural Mailbox?
   / Indestructable Rural Mailbox? #1
fidowanttobe
Mandan ND
Jinma 284 2007 Massey Harris 44 Special
Anyone out there have to replace your mailbox because the delivery person keeps whacking it? I am tired of straightening out the box and refuse to replace it again with a cheapo sheet metal one. Stainless heavy duty is my next option but the large ones are spendy.
Super easy access to it, no curve in the road and the post is angled back away from the box. No idea why she hits it.
   / Indestructable Rural Mailbox? #3
Why would the delivery person hit the mailbox? Doesn't your town have teenagers for that?
:D
Bruce
   / Indestructable Rural Mailbox? #4
Ahhhmmm,the ansewer might be right before your eyes.
Have a welder build one as heavy as it take's. Not sure what the rule is in ND,but in Tx,the highway maintainance dept will replace damaged posts and boxes free if you call them. If you set a large post or install an indistructable box they will remove it and replace with approved post and box. The state was stuck with large liability claims resulting from injurys and deaths when cars hit heavy boxes. TXDOT also spent millions replacing guardrail and signs with those that yield when struck. On county and city roads,liability fall's to property owner so city and county don't become involved. ASk your local officials before spending much on a box.
:D
   / Indestructable Rural Mailbox? #5
   / Indestructable Rural Mailbox? #6
I don't think there is an indestructible mailbox but hanging from chains and swinging poles, spring loaded post etc. in the videos posted are ways to help prevent damage.
In my area its the road dept. snow plows, mowers, and vandals that take out the boxes. I've had to repair or replace mine 5 times in the past 27 years.
The only way to absolutely prevent mailbox damage is to remove it and get a P.O. box. Then you have the inconvenience of daily driving to the Post Office to get your mail.
   / Indestructable Rural Mailbox? #7
Just my experience...but most mail carriers are superb drivers regardless of their gender...
   / Indestructable Rural Mailbox? #8
My mail is only delivered correctly when my regular carrier is working, when on vacation or off, my mail is either lost, delivered to the wrong address or I get every one's mail to deliver. I've replaced my box 4 times in 20 years. I could cure this by getting a P.O. Box as I'm retired and go out every morning to get my news paper and go right past the P.O. but I'll be darned if I'll pay the P.O. to not deliver my mail.
   / Indestructable Rural Mailbox? #9
Agree with this 100%. My father retired from the PO after 33 years. Not sure if all PO's have it but where he worked they gave out awards yearly for no accidents or damage to mailboxes.
   / Indestructable Rural Mailbox? #10
Buy huge mailbox
Place normal sized mailbox inside huge mailbox
Fill the void between the two with concrete
Mount to your existing or new quality post
   / Indestructable Rural Mailbox? #11
Some areas don't have an option. The rural area where I lived 45 years ago had a P.O. but no delivery. All local residents had to get a PO Box if you wanted to get mail. I'm still in a rural area and have delivery. Mailbox damage doesn't happen that often here so I don't mind repairing or replacing as needed.
   / Indestructable Rural Mailbox? #12
Mine was damaged several times by vandals. I finally just put it in a 5 gallon bucket with rocks. When they tipped it over, I just stood it back up. :laughing:
Now I have a 6X6 post in ground and a heavy duty mailbox. This picture was in the building stage, it has a canopy now. :D So far, no damage.
   / Indestructable Rural Mailbox? #13
Closest town(10 miles) is a college town - nuff said. Just about like RNeumann said - neighbor down the road put a standard galvy metal mail box INSIDE a two and half foot chunk of HEAVY DUTY JohnsMansville 16" or 20" diameter water pipe. Its that pipe thats light robin's egg blue color. Been sitting there, along side the road, for 3-4 years now with no damage.
   / Indestructable Rural Mailbox? #14
This is usually a pretty hot topic.
IF your mail carrier is that bad, call your local postmaster and file a claim. Thats first and foremost.
Second, gotta have a box thats "postmaster" approved. Meaning if you make some homemade conglomerate they can either make you remove or refuse to deliver your mail. OR worse is liability if you have a 50# mass of steel on top of a pole, and someone swerves and takes it out (animal in the road, slippery road, kids, etc) and that mass detaches and goes through a window and kills someone.
And third, the post. Same liability as above. As fun as it sounds to stick a 12" diameter solid steep pipe 10' in the ground and surrounded by 5 yards of concrete......your @$$ is in hot water if someone gets in an accident and injured as a result.
Your mailbox (typically) is in the state, county (whatever jurisdiction) right away. Gotta abide by their rules.
Go to lowes. They have heavy duty mailboxes with 1/8" steel instead of the thin sheetmetal. Get a mailbox post from there as well. If something happens.....you are covered from a liability standpoint. And those heavier duty mailboxes, they will survive just fine. Might have to replace the post on occasion....but better than killing someone for getting into an accident.
   / Indestructable Rural Mailbox? #15
We've had this heavy duty plastic model ($60 at Amazon) mounted on a 4" X 4" post without any damage for 17 years (knock on wood). These are strong enough to withstand snow plows but weak enough that a car driver wont be injured in a collision. Putting up a strong enough mailbox to stop a car has liability risks.
   / Indestructable Rural Mailbox? #16
Ours was destroyed by kids with a bat; replaced it with a plastic one and that worked for a lot of years. I could tell by marks on it that it had been struck with a T-post with negligible damage a couple of times.
   / Indestructable Rural Mailbox? #17
All this talk about liability if a car hits it, that's bull, what about telephone poles, I suppose you will sue the phone company if you hit one and it doesn't move and your car is totaled?
   / Indestructable Rural Mailbox? #18
Utilities have huge legal departments with far more time and money than the average individual so they can outwait and out obfuscate in order to get their result. Also, they have the support of the municipality, and therefore the court system.
How about a light tubing cage extending about two feet on the right side and angled over the top of the box so if some s@#$apple came at it with a bat from a moving car it would deflect up into the air, hopefully all the way back to their roof or back window.
   / Indestructable Rural Mailbox? #19
Good luck with that in court.
Certain things are a given. Guard rails, utilities poles, bridge supports, etc.
Its about mitigating unnecessary risks. Making a rock solid mailbox = unnecessary risk.
Why do you thing road signs, stop signs, etc are all breakaway design?
   / Indestructable Rural Mailbox? #20
Exactly...That is why both utility companies and municipalities are always getting sued...(they have deep pockets and lots of insurance) and ambulance chasers know it all too well...
It would not surprise me at all if most homeowner liability policies have clauses about mailboxes meeting USPS and municipal regulations about private property on public ROW etc...
2021 CATERPILLAR 299D3 SKID STEER (A60429)
2021 CATERPILLAR...
2020 GMC AT4 CREW CAB TRUCK (A60430)
2020 GMC AT4 CREW...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A59228)
2025 Kivel 42in...
2019 Chevrolet Silverado 1500 Pickup Truck (A55973)
2019 Chevrolet...
2011 Toro Workman HD Utility Cart (A59228)
2011 Toro Workman...
